Tall bars and seat foam
I'm thinking about adding tall foam, tall bars (cr hi protapers), with some offset triple clamps, and dropped pegs. Has anyone run this setup? I ride a lot of sx and worry that sitting higher will cut down on turning performance even with the offset triple clamps. Any comments or suggestions would be appreciated.
02 crf australian model - stock as the box it came in.
I've got Button bars and tall seat foam and it's helped out tremendously! Yesterday I lowered my foot pegs,but I haven't got to try them out yet. I first got Button bars about two years ago and it was a night and day difference, it gave me much more room to work with. I recently got tall seat foam and I can now stand up from sitting so much easier. If I've lost any cornering abilities I haven't noticed. I can't wait to ride with my new peg location. It will probably take a few miss shifts to get used to. Being 6'5" I am ergonomically incorrect for a stock bike. You got to make the bike fit your size! I hope this helps.
I'm 6'5" as well. Thanks for the info. I'm going have to try it out.
I'm 6'2" and I use Pro Taper KX Hi bend with DH1 bar mount that moves the bars 5mm forward. I believe the KX hi bend is a few mm taller than the CR Hi. This works well for me. I also have Fastways lowboy footpegs on the way! Additionally I swapped seat foam with my sons 02 CR125 - it was taller than the CRF seat. Works great!
I have lowboy pegs, windham barrs, applied clamps in the forward position and a sdg tall seat. Yoiu wont be sorry. The biggest difference in performance was the seat. I can turn a lot better no that i am all the way forward.
I run rg3 offset clamps, ceet tall foam and fastway low boy pegs. I like the pegs, but I have bent my foot in ruts and landings. I would do the seat and bars, but leave the pegs alone.
I can make you a deal on some used lowboys.
Where are you guys getting the tall seat foam/covers from? Are you using internet/mail order?
www.btosports.com has the sdg tall seat for about $80. it is complete, just install.
I've got GUTS foam with a Throttle Jockey cover, but the SDG seat would be easier and cheaper....SDG wasn't ready when I was, but we won't go there. :D
I've run Pro taper CR-Hi's and 971 bend Twin Walls. I like the 971 bend better, less sweep, seems to open things up for me.
I've got IMS low boy Pegs.
This combination seems to be common for us tall guys. :)
Got the offset clamps- love 'em. Corners better, and more stable feeling at speed (that was the biggest difference). Got the lowboy pegs- absolutely love 'em! Best $100 I spent. More comfortable, stretches out the body tri-angle a bit, and makes shifts MUCH easier. I have my tall seatfoam on the way.
so many options!!!! i just don't know where to begin... :)
just picked my crf up a few days ago...and yes those bars are low. makes standing quite a task...all hunched over like quasimoto. hey, new form of mx! "welcome to anaheim!! and the new QUASI-MOTO series!!!" sorry...
anyway, i'm 6'3...so i'm looking at all this stuff you guys are talking about. i just can't decide! anyone using tag bars? and did you guys with the lowboys actually lower them...or did you just move the pegs back? thanks.
quasimoto
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
