Oil Filter drain bolt stripped?
Has anyone had problems with the bottom bolt on their oil filter cover? Its the bolt with the alan wrench head. I think mine is on the verge of stripping about 1/2-2/3 the way in to the case. The first 6-7 turns are fine and then it starts binding. I cut the bolt down so it would only go in the case about 6-7 turns. There is enough meat on the threads to avoid addition and potential stripping.
Does anyone have a solution? I bought a tap but am a little reluctant to start tapping.
HELP!!! :)
You probably got some metal bits in there through the little drain hole in the bottom of the oil filter area. It happened to me too. I was able to save it by running a tap through the hole carefully. I globbed a bunch of grease on the end of the tap to catch the bits but I was still afraid that some fell into the motor so I took the right side case off and wouldn't you know it, nothing fell in there...heh.. Anyway, you can probably save it if you carefully run the tap in there. Just be sure to either run the bolt through a die or get a new bolt or you'll be back to square one.
Yep, had the same thing happen to me. I took the case off and bought a heilicoil kit which worked great and was easy to do. I did have some sleepless nights thinking about that bolt untill I fixed it. :) I'd still be working if my crank gear nut hadn't loosened up and gone into my case. Now I have some expensive bathroom hall passes in my classroom.
Thanks for the advice! Does the hole in the case go all the way through? or does it stop short?
If you can get your hands on a time cert, that is the best and most permanent repair you can do.
Bonzai :)
I agree with Yamakaze, I had the same bolt strip and I did the time cert and it worked great!
Must be a problem with that bolt, because mine has a rough spot as it goes in as well, and what exactly is a time cert ? I have seen that on here before, but never seen a web page or pictures with some details.
Ditto - What is a time cert?
I had to use a timesert and strongly recommend them!! The web page is http://www.timesert.com/ all you need to do is call the number on the web page and tell them what size kit you need.
I keep my 6mm tap on hand when i change oil. If the bolt does not want to go in easily because of debris in the threads, I simply clean the threads with the tap. It can save you from having to do the repair.
If you have to do the repair, you need to remove the side cover. The hole does go all the way through. The cover is easy to remove and you can re-use the gasket. I have had mine off several times with the orig. gasket.
Thanks all for the awesome advice. I'll try cleaning the threads up before going with the timesert.
I was literally loosing sleep over screwing up my new bike. I knew I couldnt be alone on this problem.
Thanks again..
Damn! Same thing happened to me way back when I changed my oil for the first time. I did the same thing as Sirthumpalot short of taking the side case off. I just went slow and kept taking the tap back out and cleaning it off. I found my bolt to have a couple boogered up threads right at the end. I just cut off the bad threads and ran a 6mm nut up and down it a couple times. Put it back together with no problems since. It's really interesting to see how so many of the bikes share the same problems and how this site brings it all out. I wish the big factory guys were reading.
I had this problem on my 400. I used a small pair of vice grips to take it off.
Sorry for the delay, The hole goes all the way through, but to repair it safetly the side case has to be romoved to make sure no particles go into the engine when the repair is made.
Sooner rather than later, your going to have to fix the thread in that hole. Unless you plug the drain passage from the filter cavity. Mine stripped, I plugged the drain, and put a helicoil in the bad hole. No more problems. Dont be loosing any sleep over it, its not a big deal, even if you do strip the hole completely.
Run a tap in it with grease to clean the threads up and if that doesn't fix it use a timesert there the best.
Just for future referance it always best to but a little bit of grease on the bolt threads before reinstalling. This will help keep the threads in the cases in good shape when you remove the bolt. This problem comes from the expanding and contracting of the cases and having different material come in contact with one another. Its always a good practice to put a little grease on all bolts that are removed offend.
Shawn Mc:
What did you plug that drain with? TIA
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
