Valve clearance on takegawa 88 r stage kit
Last night I bolted on the takegawa r stace kit with the new cylinder head,rocker arms, cam and 88cc cylinder and piston. I stopped because I had questions as to what the valve clearances should be whith this kit. Should I adjust the clearances to 0.002in.(0.05mm) like my service manual instructs or something different? Any imput on this subject would be great thanks! :)
Or you can run them both at .006 if you like to keep it simple. You also can run em a bit looser (up to .009) for a bit more bottom end. They will make a little more noise but it is all cool.
