Seal Savers - do they work?
Well while watching the various posts I am looking at the Seal Saver ad - Does anyone have any comments on the pros or cons of these?
I would think that while the seal savers keep the dirt out they also must keep the dirt which gets in, in? Which is not a good thing as the dirt cannot fall off like it would if you had no seal savers. I myself like being able to look at the fork legs and see if there is anything up near the seals. I've looked and the seal savers too and thought the same thing as I think you are now thinking. Do they work?
When I had my suspenders ravalved By Dick's Racing in Vegas, he advised me not to use them. Little rocks have been know to wedge themselves in between the noeprene and lower fork tubes scuffing them up and causing seal damage.
I used them on my 2000 and now have them on my 2003. Never had a problem with a seal on my 2000 while my friends and relatives without them replaced numerous seals. Perhaps just lucky but I'm using them again.
Instead of seal savers just shorten the spring which goes around the seal,this will increase the tension which helps the wiper push off dirt
I tried using them at the beginning of the season, because of leaky seals. I found that they held too much dirt on the inside of the seal saver, so I took them off.
Thanks all for the quick and honest replies...
Roger :)
On my Wr, I was having to clean behind the wipers after every 3rd ride or so, or else they would weep pretty bad.
On a recommendation, I installed a set of SealSavers, and they have been great. They are super tight, and I honestly feel that NOTHING gets behind them.
I have had them on for 2 months, and I have no problems, and I would recommend them if your forks like to weep.
i use seal savers and havent had problem with seals since they have been on my bike about 6 months.there is no way dirt is going to past them into seal.first they are tight enough that dirt and dust is pushed down away from seal by the very end of seal saver.second if you flip up sealsavers and wash inside ever once in a while you will have nothing to worry about.seal saver clean dirt and mud off fork tubes before it has time to dry leaving less chance to scratch tube.
I use the neoprene booties on my 02 400 and my sons 00 200EXC. The seals on the 200 are nearly 3 years old and STOCK with no leaks.
We live in Ohio and the bikes have seen their share of mud. IMO they are well worth the money!
Good luck,
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
