Shock Spring Replacement
I'm going to replace the shock spring on my DRZS, and I was wondering if I will run out of preload adjustment, before the spring comes loose. In other words, will I need to somehow preload the spring in order to install the new one? Is the "subframe pivot method" still the way to go??
the preload collars will be off the spring need for special far as method,lots different opinions.i just take my subframe off,its easy plus i like to clean out the air box and stuff.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
