DBa rating on the YZ450F
I would like to race an enduro event next month but need my 450 to meet the noise requiement. Does anyone know what the DBa level is of the stock YZ450F?
Has anyone bought the quiet tip for the promotobillet spark arrestor? I was hoping to go with the PMB $150 dollar S/A quiet tip combo opposed to the FMF Q-muffler at $300.
Additionally, any ideas what the DBa level is on the 450 with the PMB SA and quiet tip?
Any help appreciated... :)
i have heard the fmf power bomb header works like a little muffler too and take a fe DB out.
I had my 450 tested at hollister.I tested 96db 20" out with just the PMB sparky.I am going this sat and can do another test to make sure it was tested correctly.I'll let you know if it changes. :)
Please repost your DBa results when available.
It's a shame to get rid of the titanium end cap. I put a PMB in my 02 426 and the quiet core drops the db's quite a bit. I haven't ridden with it yet so I don't know how much power it will suck up. I talked to Terry at PMB and he said they haven't done any sound tests on the YZF's yet but the CR450 was down to 96 db's. Which race are you going to do? I'm gonna race the D36 race at Wileysville in November. I wanted to race the Lilliputan at Hangtown in a few weeks but seperated my shoulder at Hangtown 2 weeks ago. What db's are they looking for? I have heard they want 100 db's but I have also read that now they want 96 db's. I hope the PMB gets it low enough to pass the D36 sound check.
Let me know when your going riding and we can hook up. On second thought, I swore I would give my shoulder till the end of the month before I rode again. After that, I'm game.
Oh yeah, about the FMF Q silencer. I had one but wound up sending it back for a few reasons. First off, it kept hitting my rear brake caliper when I would bottom the rear suspension. The joint where the header and silencer connect also had pretty good exhaust blow by. FMF told me to use thread tape and hi temp silicone as a sealant, neither worked. I also dreaded taking that thing on and off because the mounting clamp was atleast a 2 person job. The performance wasn't bad but I thought they needed to do some additional engineering work on it. They may have since then, I don't know.
another problem with fmf quietcore is it sticks out to far. first time you loop out, it gets torn off or broken it half.
I think the enduro is on the weekend of Nov 24th somewhere near Stoneyford. My buddy is into the D36 enduros and talked me into riding this race. He received a flyer on the event - I think they are calling it a family enduro? I race MX and this would be my first enduro. I am a little concerned with 450's 1.8 gallon tank running out of petrol.
The D36 rules state the DBa should be 99 but my bud said they were testing for 101 at the last race. Either way I hope the PMB will work.
I will probably ride out at Hantown next week on Wed practice. #26
Keep in touch on the enduro..
i tested again and was at 96.4-97.4. So you should pass no problem. :)
I was there when Blue tested I can vouch for it, I saw the whole darn thing I was a witness I can prove.
Ok I said it Blue thats 20 bucks ya owe me :)
Awesome! thanks for the info. I'll order the PMB S/A.
I will keep you posted on enduro schedule for Nov. I ride tracks all over northern CA so if you see #26 on a YZ450F stop by and say hello.
The Blue One,
What rpm did you take the reading at? The test rpm has not been published for the 450 yet, but in a pinch I would guess that any testing person/official would get a next best temporary substitute value of using the spec for the 02 426 - 4500 rpm. The readings are very rpm sensitive and testing at the correct rpm is key to passing the test.
It was at 4500 just like the 426.
The Blue One,
How do they determine the RPM to do the testing at? It seems very subjective.
How are the sound wars going out there in CA....Are the sound police out in force at every event as was threatened earlier this summer?
Bonzai :)
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
