Stormcycles Hot start button.
I saw an ad for a new company that's making hot start levers for the CRF/YZF. It was $39.99 versus $49.99 for the DR.D setup so I figured why not. They look the same actually and I was impressed with the workmanship. Fit and finish was good and it works as it should. So if you need or want a new hot start lever give this one a try.
Do they have a website?
Nevermind, just typed in the company name and it is under construction. Where did you see the advertisement?
Cycle News had the ad last week. It's the glossy cover with Colin Edwards. Look in the classifieds and you'll see a picture. They also offer a really trick tool to adjust the clickers on forks with offset bar mounts.
I was talking to a machine shop today about having a tool made with a tiny flat head with a 90 degree angle to fit under my bars to adjust the compression. Geesh, the stock bars on the stock perches wouldn't allow for a straight-on screw driver adjustment. Then, with an additional 3mm forward with my Scott's Performance perches and ProTapers, there will be no way for a screw driver to reach 'em.
I'll call the company and ask them to send me a brochure.
i don't know what's the big deal about moving the hot start to the right side is...I did it with Dr....duback and didn't like it....too late now...
The guys at Goki and Storm Cycles have been around a very long time, like decades. Larry and Mike are personal friends of mine, and you can call them at 818 998 0852.
I think the reason some folks do it is because of starting it in gear, like in a technical off-camber like section, holding both the hot-start and clutch at the same time for folks with smaller hands may not be able to do it as easily as just having the hot-start pushed in with the right hand's thumb...
hope this helps,
I was about to change mine back from the Dr. D and hadn't gotten to it yet, but last Sunday I broke my clutch perch and was able to moto the rest of the day on an old Yamaha clutch perch. I'm convinced now, that for that one reason alone, it is worth it. :)
<font color="brown">You guy's want to see a really nice Left side Hot Start? A member of T.T. makes them. He goes by RC49. I have one on my bike for a long time now. It hold's up great and the workmanship is amazing to say the least for a guy just making them on his spare time. You'd swear it was made by an after market co. for sure. Sort of cool that there is very few out there!! There might be 5-10 bikes at the most that have them!! I think it was 44.00. Got it so I could run handguards. In my opinion it's the NICEST one out there!! It's at
I've got the RC49 hotstart too, and gotta say I couldn't believe the craftsmanship when it came in the mail. Beautiful finish and it works perfect. It mounts on the left side, but I don't find any problem pushing it in while holding the clutch in, since you use your thumb for the hotstart and fingers for the clutch. I'd be nervous if it was on the other side because of the tendency to twist the throttle--as it is, I hold the front brake to keep away from twisting it, but with the thumb pushing in, the hand naturally wants to go that way.
I like the one made by RC49, but I run a juice clutch. I e-mailed RC49 to see if he would make one for the right side/throttle side. He said he would look into it but never got back to me. I just use the stock perch mounted on the right side with the hot start lever facing down. I can reach it easily by holding the M/C and using my thumb to engage it. Works great, but it doesn't look so good. People always ask, "does it hit your leg or knee?" the answer is no. Of course I wear Knee Braces so I probably haven't noticed it hitting my leg.
Motorep, can you post a pic of the hotstart lever?
I've yet to use the hot start on my 03 CRF.
- Cold: It starts 1st or 2nd kick whithout fail.
- Hot: It's never missed a start on first kick (no hot start)
I'll leave the hot start on but maybe its just for looks :)
I have an rc49 hot start and I agree it's a work of art. I live in Australia and I'm sure I would have the only one here. THANKS RC49 :)
I agree with it hot you don't need the hot start a lot of times. It's when you fall and flood it is when the hot start mode kicks in!
How do you like your Azonic Bars?
<font color="brown">Their great and super strong since their oversized PLUS the cross bar. Got them in the Larroco bend which is a little higher and less sweep. Had some bad falls and not a bend in them yet! Since they first came out they updated them. They use to be actually two bars in one. One tube slide into the other and were rated very stong then. Now their just one solid bar. Called the deluxe bar. Think I've seen them as cheap as 85.00. I paid 100 for mine.
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
