Vibratach
Hi,
Does anyone have good knowledge of using these things?
I bought one, read the manual and tried to use it without much luck. Is the reading correct when the little wire is vibrating a lot at the end? Like a big dog that sees a bone?
I tried to calibrate it against my Toyota 4-cylinder and my Suburban V-8.
Engine Tach Vibratech
Toyota 2000 4000
Suburban 2100 3500
Lawnmower ---- 3000 full power
XR400 ---- 1300, 1/8 turn on idle 2600.
I'll give it another try, then I'm sending it back.
Anyone know of a good inexpensive digital Tach?
The manual is a little vague but as best I can tell, when the wire vibrates with the most movement you are on the RPM of the motor. It is certainly not as accurate as a digital tach but OK for quick idle adjustments or roughly dialing in the fuel screw. It does take some practice.
Also this is designed for a single cylinder engine so I am not sure it would be accurate on you cars.
How do you know your XR 400 idles at 1300 rpm?
Yo can get an induction type tach for $30-40. Here are a few links:
http://store.yahoo.com/powerproductsoutlet/noname2.html
http://www.sendec.com/meters/
http://www.jackssmallengines.com/hour_meter.cfm
I have both. I use the Vibratach on the road and the digital tach in the garage.
Fellow TTer gave me this site http://tinytach.com/
Has function as a tachometer (goes to 9999rpm so can't really see if the 13,500rpm rev limiter really works) also used as a maintenance hour log to keep track of time on motor.
