suspension help
I have been TRYING to understand my suspension settings, knowing they are wrong for myself, and need a little advice.
On landing after jumps, my front end is incredibly hard. Stock settings. I know from dirt marks on the front fork that I am upwards of 3 inches from the bottom-out point and can feel the rebound too hard. So, following previous posts, I moved the rebound (top) out 2 clicks, and the compression (bottom) in 1 click. Does this sound right to you guys. I don't want to sound stupid, I'm just trying to understand the philosophy here. Also, where exactly are the TWO compression clickers for hte rear shock. I can see the one on the linkage underneath but can't see the other one. Please help.
idahusker,
Although you don't want the bike to bottom at the conclusion of every jump, you do want a soft landing.
Let me see if I can make some sense of this.
In short, the feeling that you get when a bike is nearing the bottom of its stroke is mainly controlled by oil level.
The process of getting there, slow or fast, is controlled by damping rates which are controlled by the "clickers".
Begin working with these two parameters. If this does not solve the problem you'll need to enter the realm of spring rates and valve stack changes.
As for the rear end the clicker controls are reverse in that the rebound is on the bottom and compression is on the top. You should see a small screw within the high-speed nut, (usually red) located just above the reservoir.
You may also want to take a peak in the back of the manual in the "Settings" section for further details.
DaveJ
You can get some good help off of Motoman's site on this subject, thats where I learned to set mine up.
Motoman's Site
It sounds to me like you turned your adjusters on your forks the wrong way. I could be confused and telling you backwards, but, the compression (on the bottom of the fork) is out for softer and in for harder. And the rebound, which is on the top of the fork, is in for slower and out for quicker.
As for the shock, the rebound is on the bottom and looks just like the rebound screw on the forks. The two compression adjusters are both on the top. The slow speed adjuster can be adjusted with an adjustable wrench or end wrench, but you shouldn't ever really have to adjust it unless you get really serious about this. The slow speed adjuster is adjusted with a screwdriver just like the other ones and is located in the center of the slow speed adjuster.
If this doesn't make any sense, go read Motoman's site, and if that doesn't work bring your bike down to practice at Mountain Home tomorrow and I will explain it in person the best that I can.
Cory
If you want to make your suspension softer then you need to wind the compression clickers out (anti clockwise) compression clickers are located, bottom of the front forks and there are two adjustments on the rear, high and low speed compression,low speed is in the centre at the top of the shock and the nut is your high speed compression, the high speed will affect your landings after a big jump, and low speed will effect your woopies, start by getting your copression right, then start playing with your rebound on the rear (bottom of shock) wind it in and out, bounce on the bike and feel the difference, this will make it much easier to ajust the front rebound (top of forks)
Hope this helps.
Find the question
"450 question (suspension)
I wrote an answer that might help you.
  • Similar Content
    • By short450
      Only used it a few times and it is practically new.  ONLY $200 with shipping to the lower US states.
      Text or call me at 801-36two-8899
    • By short450
      Too much stuff in the cabinets and need to clear some out.  I have a lot of parts for 2010 - 2017 YZ250F and also YZ450F bikes.
      ***The suspension and triple clamp in the pictures have been sold***.
      Swing Arm for 2014 - 2018 YZ250F, 2014 - 2017 YZ450F
      Oil Tank for 2010 - 2013 YZ250F - $100
      Brand New Gas Tank 2010 - 2013 YZ250F
      Used Gas Tank for 2010 - 2013 YZ250F
      Cables and other parts for 2010 - 2013 YZ250F - Let me know what you need and I might have it.
      Various plastics and parts for 2010 - 2013 YZ450F - Let me know what you need and I might have it.
      Very low hour clutch basket, hub, pressure plate for YZ250F.
      Intake and Exhaust cams from a 2008 YZ250F with only 8 hours.
      Intake and Exhaust cams from a 2013 YZ450F - Very low hours
    • By High On Octane
      Got a break in the weather over the weekend, and was finally able to get out on a track for the first time since October.  I know I suck compared to a lot of guys (and kids for that matter), but I always have a blast twisting a grip and roosting some dirt!  Here's a raw uncut lap around the MX track at IMI Motorsports Complex in Dacono, CO.  Was a fun day despite some wind.  Also, there was a drift car club having a meet on the road course.  So, got to check out some drift car action while we were taking a break.
    • By PFOS58
      Lightly used Clarke Gas Tank (model #11614) for a 2010-13 YZ450F.  Includes cap.  For fuel injected YZ450F, so needs to have fuel pump transferred over.  Rest of stock tank hardware fits perfectly.  2.8 gallon capacity, so great for desert, hare scrambles, or WORCS.  Retails for $240.
      E-mail me with any questions or offers at billsworld@scinternet.net
      Buyer pays shipping from 84726.
    • By faizakhtar125
      Like this comment if you have a YZ. I want to see how many people have YZ's, especially YZ125's
