Who is waiting for Thunder Ally pipes????????
Just wondering who else has been waiting for their Thunder Alley pipe. I ordered mine 13 Sept and was suppose to get it the 26th. It's still not here. I did have mine ceramic coated and here lies the problem according to Bob. Embee currently has 12 systems they have been sitting on for 2 weeks. I called Bob Monday and he said Embee told him he would have them by today. So hopefully you and I will see our pipes late this week or first of next week. :D :D
Somebody with a Thunder Alley tell me this is well worth the wait. That I will be totally impressed with the performance.
I ordered mine on the same day as you and I just got mine last thursday, but I didn't have it coated. Just riding it down the street it feels like it has a softer bottom and revs a little slower than the powerbomb/powercore setup it replaced. I'm going riding after work today and I will probably mess with the jetting, I'm currently running a 168 main and the rest stock. Oh, yeah its a '02 YZ426. We'll see.
It is worth the wait. You will be totally impressed by the performance.
You're welcome :)
The coating is also very nice. Embee turned mine around in about ten days, so they must be pretty backed up right now.
What jetting is everyone else running with this pipe? No, I havent done the BK mod, my '02 doesn't have any off idle bog or stumble so i haven't seen the need for it yet. So, maybe someone running the TA without the BK mod could help me out?!?!?! I'm thinking my jetting must not be in line with everyone elses.
I'm waiting for a pipe and having it coated. Bob told me he is about 15 days backlogged and having it coated is somewhat unpredictable, could be 3-days to a couple weeks. I just placed my order so we'll see.....
Well, my TA is on a Honda, but here are my words...
Be careful about automatically bumping the main jet size up right off the bat. I did and after some dyno testing and rejetting, I discovered the 170 (stock for me) made the BEST power. In cooler weather of course I will have to go richer, but for 85f - 95f temps the stock jetting is spot on. Crisp and clean.
On the CRF450 the bottom end is simply...amazing. Dyno shows a small drop in the mid and then goes on to ever so slightly out perform the stocker on the top. O track though, I feel no loss in the mid, and this shows why the dyno is not the "end all" of exhaust system design. I can only tell you this, the TA is flat out much faster than the stocker in the bottom and into the midrange...I can skip from 2nd to 4th gear and the torque simply powers it's way along, pulling hard with hookup! Less shifting is the ticket! Enjoy it, I am positive you will love it as we have...
Hick Id ride it without messing with the jetting first. Ive been rethinking my jetting since I got mine and went up on the pilot and the main. It does pull harder on the top with the bigger main, but the I think Im just a little too rich on the bottom. Ive got a 45 pilot, and the needle is in the #3 postion(stock 00' needle). But this was summer, Im betting when the temps come off 100, down to the 60-70 range, I'll be spot on.
Your going to be blown away by the T/A pipe.
I ordered my pipe on the 30th of September and it is being built today (10-10), but because of the holiday it probably won't be here until Tuesday. Waiting sucks.
Jetting with TA:
Vs. stock I'm on the verge of needing a larger pilot, but not quite. A richer idle mix setting was needed but I'm still around 2 turns out.
I did ride the TA back to back with my Pro Circuit T4, and on bottom it seemed better, and mid to top it was definitely better. Jetting did not change at all from the PC to the TA.
Hope this helps.
As an aside, this whole "what jetting with this pipe?" thing is largely, I think, a vestigial (there's a word for ya!) two stroke knee-jerk type of thing. Being that your average aftermarket pipe is less restrictive than the stocker you may need to richen the pilot circuit, but going from one aftermarket to another isn't, IMO, going to require, or benefit from, any jetting change. Just my opinion...
What is the difference between the '00 needle and the '02 needle?
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
