Carburator Experts Help
Question for all you carburetor experts:
I am running the stock Jetting and have done the BK Mod. The bike runs great and starts 1-2 kick. What I have noticed recently is a little backfire on decel. And when I shut the motor down I get a Burp from within the pipe it sounds like. Almost like you would exhale after a hard exercise. :):D
Question: Will playing with the fuel screw help correct this. Or should I maybe look into a larger pilot jet.
Thanks in advance for the help,
I am not sure about the burp, however the fuel screw will eliminate the popping on decel. Thurn it out to richen it up a bit. Some popping on decel actually gives better throttle response. Make sure the bike is thoroughly warmed up before making any changes. If you dont have a manual check out Motoman393's site as it has an online manual. Just follow the manual to the letter and it will go fine. remember to only make one change at a time to reduce the variables. Good luck
If it feels good then I wouldn't worry about the minor popping or the soft backfire when you turn it off (mine does this too).
The short answer is yes. The strange issue is the burp...That normally happens when gasses are not passing fully through the exhaust system and are ignited in the can or the headpipe with the rush of air entering the chamber when the engine is shut down....Basically loading up. Check your entire exhaust system for leaks. You may very well have a connection siphoning air into the system causing this problem. I've seen this twice before where removing and re-seating the entire exhaust system cleared it up.
Bonzai :)
Hey yamakazee, thanks for the tip!!!!!!I've fought with my jetting for week to get rid of that darn popping.
  • Similar Content
    • By BDTRENT
      Selling an FMF Power Core 4 exhaust system off my 450FX. Exhaust has 80 hours and is 100% functional. This will also fit the 14-15 YZ450F and 16-18 Wr450F. If needed I can also include new muffler packing although it does not need it.
    • By Woody Oakson
      I have a 2008 YZ450F with a stock header pipe and Pro Circuit T-4 Slip-On Exhaust. I'm 99% sure the slip on is shot because its loud as hell and when I take it off and shake it it rattles. I would repack it but the screws are all stripped ect.
      Anyways I've gone over the carb multiple times and I've got it running pretty well. The only issue I have with the bike is that it sputters and pops around 1/2 throttle when I hold it there. When I give it full throttle from any RPM it runs great or when I give it about 3/4 throttle it spins up like a top to redline.
      Initially the popping and sputtering was way worse I made the situation better by moving the pilot jet up in a few sizes from a 45 (stock) to a 62. The issue has gotten way better since then but I'm not super sure what to do from here. Should I keep moving my pilot jet up in size because that's a pretty large jump right? I tried changing my needle clip position but that didn't help much if anything it just made starting it worse and little to no impact on the ride.
      Any input on this would be helpful. I don't want to buy other slip on. Also as for the rest of the carb I'm very sure everything else in it is what it needs to be at. I've replaced all the gaskets and O-rings cleaned all the jets, valve holes ect. fixed the accelerator pump timing. I just thinks its strange that my pilot jet size is going so far from the stock 45, but all symptoms point to the bike running lean.
    • By Haydenbaha
      Hi I was wondering if y’all have been using a 450 on your YZ250F?
    • By RockerYZWR
      Excel Takasago 17x3 front and 17x5 rear supermoto wheels with Metzler M3 tires in very lightly used condition. Less than 200 miles total on the setup. Warp 9 spokes. Rear has a Talon hub with 45T Sunstar steel sprocket and OEM rear disc, and front has a polished OEM Yamaha WR450F hub (for the stock speedometer), with a Motomaster 320mm disc. Included is a DID gold o-ring chain, 14T front sprocket, and front brake caliper adapter for a truly turn key setup. Everything is in excellent condition, not a single scratch on these wheels. Came off my '11 WR450F, but will fit many different Yamahas with 20mm front and 22mm rear axles. Asking $1400 plus shipping.
      **Will be driving up near Atlanta, then to northern Louisiana, OKC, and down through Dallas and Houston, TX soon -- can meet or deliver if in the area (Aug 31-Sep 9)**
    • By YZ426fNC
      Hi I’m new on the forum and I was wondering if a 2001 Yamaha YZ426f clutch is interchangeable with a 2002 Yamaha YZ426f clutch thanks , Coleman
