Suspension setup on a YZ250F
What springs(front and back) do i need, the stock springs are in it at the moment, and the fork oil level is at the max. The problem i am having is that when i land a (soft)jump it is nearly bottoming, and has bottomed a good few times, the i bought it off said he had it set up for a 10 stone rider.
I am 80kg / 176lb / 12.5 stone, the measurements i got off the bike were...
Shock static sag = 15mm
Shock race sag = 85mm
Fork static sag = 35mm
Fork race sag = 65mm
Any advice would be much appreciated.
Std springs are 0.44 kg/mm and 4.8 kg/mm (or 5.0 progressive on a Euro spec). I weigh 90kg. I installed 0.46 kg/mm front springs and 5.2 kg/mm rear spring. Oil level is at 100mm. After changing, I don't bottom out any more, but I found the forks a bit harsh on landing. I reduced the harshness a bit by winding the fork compression damping adjusters out completely.
See http://valving.racetech.com:81/cgi-win/racetechv2.exe for some more info. In particular, they say that a 250F is set up for a 74 kg rider as standard.
Hope this helps.
