installing xr 70 tb clutch
im installing a TB manual clutch on my xr 70. (Its the same as a 50) and i have all the old suff removed. I installed the new shift shaft, im confused with the star shaped thing and the stopper arm, i marked how they all went and have it all back together but when i shift the bike (not with everything together) it does not shift, it only goes up 1 and back down. im not sure what im doing wrong:excuseme:
just went outside and fidled with it a little bit, i moved the large primary gear to the left a little bit and now it shifts into all three gears, but if i move it any other way it just goes back into shifting in one gear...so there is a sweet spot where it just shifts fine??
also it is harder to get my shift lever on the shaft any help on that?
everythings fine dirt bike trannys arnt ment to fall into gear they have to roll to get the teeth matched up
