End Caps
I just finished making an end cap for the same reason you want to. I started out with a flat plate about 1/16 in. thick and cut it into a 4" circle. Copied the bolt pattern off the stock exhaust. Bought a piece of 1 1/2" sink pipe and cut a hole in the middle of the plate for the pipe to slip through and held it all together with JB Weld (the pipe has a flange on one end). I have not installed the spark arrester yet. The db is the same as the stock tip, yet you can see right thru to the inner baffle (sound test was done with a meter 20" away at 45 degrees). I will post the sound results in a day or so. A little creativity will get you a good looking functional tip.
