Where to get DRZ airbox decals?
try factory effex , if they don't make them pre cut for the drz they have 8x10 sheets of carbon fibre decal material that you can cut out yourself , just make a template using painters masking tape on your side panel , peel it off and stick on the 8x10 sheet and just cut around it .i found this method works pretty good . 🙂
I used an old wallpapering trick for the hump. I made a cut from the top of were the bulge began down to the bottom. I overlaped the decal on itself and cut again through both pieces and pressed the seam together. You need to do this when the deacal is warm or else it will spread over time.
Ă—
Ă—
