Case Savers - What and Where to buy
That must be the left side-probably an extra notch cut out for the starter motor? You can see the notch in the photos. Might fit the kicker but would have the notch there for seemingly no purpose. Protective qualities would unaffected. Baja Designs also sells guards but with different design approach. Bolts to the skid plate-looks very industrial. I think the CFC has a more finished look.
the name your thinking of is fordy2dr,he's da man,thats if your after CFC side case sheilds,what we call case savers are the ones that go around the front sprokets and chain to protect the engine incase a chain brakes or a rock is brought around by the chain and it stops it smacking into the case and bracking it ,a good one of those is made by an aussie company called b&b aluminium they are stong ,look good ,and are cheep as chips.
IAN
Ă—
Ă—
