cable lubing
Ok so I was doing some work on my bike. I went to lube my cables(first time):busted: I have a tusk cable luber from rockymountain and I took my clutch cable out of the perch and attached the luber to the end. I don't know if it was on right because it didn't have directions. So I pulled the rubber boot back and but the it on with the large hole against the cable and the other end had the bead like thing:prof: that goes in the lever sticking out. I tightened it and tried to spray the stuff in the little hole that appeared to go into the rubber center. Basically I just made a mess...I didn't even attempt the throttle since I have never taken it apart before. What am I doing wrong?
The rubber hole on the top left of the picture is what I was trying to spray into.
Ok so I was doing some work on my bike. I went to lube my cables(first time):applause: I have a tusk cable luber from rockymountain and I took my clutch cable out of the perch and attached the luber to the end. I don't know if it was on right because it didn't have directions. So I pulled the rubber boot back and but the it on with the large hole against the cable and the other end had the bead like thing:prof: that goes in the lever sticking out. I tightened it and tried to spray the stuff in the little hole that appeared to go into the rubber center. Basically I just made a mess...I didn't even attempt the throttle since I have never taken it apart before. What am I doing wrong?
its always messy. but you really need to take that whole thing apart top to bottom and learn how it works. you wont screw it up. in fact do the same with the whole bike. you will need to take it down to grease the bearings, in the swing arm and axles. its fun. and you will enjoy that part as much as riding. at least i do.
Ok well can I do it that way for now? I am gradually taking more and more of my bike apart. I don't have anyone to learn from so that doesn't help.
go to .....twmx.com
then to the how to section
there is an article about lubing the throttle cabels in there
hope that helps:thumbsup:
you could get the more detailed shop maunual. but yea do what your doing. it wont hurt anything. just remember this thought. watch what it looks like when you take something apart. never ever over tighten a screw or bolt period. and when you can buy a torqc wrench. you can pick them up for less then 75.00. make sure the wrench is in the parameters of the torqe levels of the bikes parts.
Here you go! Here is my internet page How to section and it's written in our language. Just scroll to the bottom and click on video and every problem will be solved :applause:
www.mxvelenje.com
Yeah, I do have a torque wrench. Thanks for the tip though.
Today I'll be taking the top of my cable housing apart again to replace my clutch lever so I am going to give this cable lubing business another shot.
Oh, and MX Peter, I didn't see the video and had some trouble understanding anything to find it...
i saw his video, plain as day at the bottom of the page. just press play.
good video. plain and simple instructions.
I cut a 4 inch piece of 10mm(3/8") heat shrink tubing.
Shrink it over the threaded insert on the cable, fill with WD 40 and leave overnite. Works a treat and costs little.
Hmmmm I tried again and it loaded right up this time. The first time I was on a different computer and the page came up blank. It's all good. I guess I was pretty much doing it right anyway. Thanks
Forget the cable luber, just buy a new cable they're cheap. It will feel worse shortly after you lube it anyway.
Best thing I ever did was install a Magura hydro-clutch.
If you think that 30€ (44$) is cheap for a clutch cable than be my guest :cry: Specially if old one is not teared of and can be lubed and reused again :applause:
Magura hydro-clutch is good, but sadly also expensive :)
Too bad you get hosed on parts over there. They're less than $15 here.
ooooo you can call yourself lucky end of words :cry: Then really you can just change cables and is OK and CHEAP
Yes they really robs us here every thing is so expensive. I get headache when I have to change something :applause::)
