Oil Leak... ideas?
I just finished installing the new eddie engine and filled with oil.
Before starting it, I noticed a leak below the bike and have determined it is coming from the connection at the oil pipe/engine.
I have removed it and inspected, the little insert in there is a little loose, and I see no oring or gasket. When I wiggle that little cylider shape piece on the end of the pipe it causes more oil to flow.
The fiche on ronayers doesnt show anything in there, like a gasket or anything...am I missing something, or is it possible I tweaked it and it is not sealing correctly now???
Thanks,
This is the union of the leak....you ca see the little cylinder shaped insert in the end of the pipe..
and this is where it connects at the bottom of the engine
if memory serves there is an oring that goes there
edit yeah I just found this pic that cylinder is removable in this pic it shows the other end with the oring in it still but no cylinder
ronayers is where I usually get stuff but any std oring of the right size should be OK. there is a recess where the oring fits into in the engine case or frame depends which end actually there is an oring at either end are you missing both ?
heres the engine side showing the recess the id is the size of the cylinder the od is the size to fit into the recess
Yea, I looked at that fiche as well, but I think #6 is the top of the oil pipe hose, and my leak is occurring at the bottom of the hose.
I wonder if that #6 and #8 are the same 2 parts in the other end of the hose....
There is a little round cylinder that goes in there. I think there was also a copper washer or something. Do you have the little cylinder? Looks like a sleeve.
I've got the cylinder, thats it. No copper washer, o-ring, gasket etc....
The Fiche is not displaying the bottom pin and o ring. If you scroll down you will notice that #7 and #9 are listed as two items each. Sometimes the fiche is funny and needs to be deciphered.
So what are you saying?
7 and 9 are not related to my problem location though?
If you go to another on line parts place (like http://www.powersportspro.com) or use the hard copy parts book. It will have a "required" quanity.
Item #6, shows 2 ea. As we know the top of the hose only uses 1, the other must go to the bottom.
I alos just went out to my bike and checked,,, top and bottom are the same O ring:p
Thanks for the help folks. I ordered em up online.
Im guessing that o-ring was left on the engine side during removal and fell off during packing or transit or something...
if it was with the motor when i recieved it would have come back in a seperate bag along with with any other loose parts.
Yea, I imagine it probably was not.
When I was working on the oil hose last week the little cylinder slipped out of the hose. I'm wondering if the o-ring slipped off that night and when I looked at the fiche I couldn't see anything so i figured it was just the cylinder. I had a hunch something should be there, but there was no evidence of it, so I moved on. When I saw the leak, I knew it had to be that area.
This was the fiche I was using..it has the quantities listed for each part.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
