Checking Float Level 06 WR250
I have had a rich jetting condition for a while now and some plug fouling
But I am not sure what the float level hight is suppose to be or how to check it properly
With the carby upside down the float seam is level with the body of the carb...
Is this right the procedure and the float level?
I am running the following jetting:
Slide#4. PJ:27.5. MJ:390. Needle:60 3rd clip. Air Screw: 2 turns out
1500' 26-30Deg C. Plug NGK: BR7ES
The float seam should be level with the carb. body, yes, but if you hold the carb upside down it could be compressing the spring in the valve. You should only lean the carb over enough to close the valve, not enough for the weight of the floats to compress the little pin on the valve.
If the spring is compressing and its still level, that would make it leaner so float level doesn't sound like your problem.
In my experience fouling plugs has always been a rich pilot, and your fuel screw being at 2 turns out also suggest your pilot is rich (although I've never had much luck jetting by what the fuel screw says). The difference in fouling in less than 10 miles and never fouling can be as little as one pilot.
Even though its a colder plug a BR8EG doesn't foul as easily as a BR7ES because it has a thin electrode that is easier to fire (based on actual experience). That would only prolong the fouling though so it doesn't matter, the cure is in the jetting.
The thing comes stock with a 10 or 15 pilot so you can test leaner pilots, although I wouldn't go as lean as stock.
I posted some pilot tuning info (to make sure you don't go too lean) in the Jetting Help? thread.
Uhhh.... just looked at the "Jetting Help" thread and obviously you already knew about it. :applause:
Anyway, I think you should try a 25 pilot if your still fouling plugs with the 27.5 and see if it helps.
I posted in the jetting section as well....
The air screw like you say doesent do much that I can tell less than 1 turn in and it stalls more than 1.5 turns out end I cant tell the differance untill it falls out!!LOL
The manual says stock PJ is 35!!
It had a #3 slide in and I changed it to a #4 which is better leaner..
The jetting chart in the crappy hand book never goes lower than a 30 PJ no matter how high or hot it is....
I will order a 25 and try it this weekend....
This idle jet stuff is very confusing,a mate was told that anything smaller than a 30 was dangoursly lean and yet as stated in a previous post standard is
a 10 or 15,my mate runs a 32.5 and is mostly not fowling plugs,2 or 3 rides no dramas and then he will fowl one,BTW this is at sea level and up to 1000ft,this is on an 02 WR 250
I am running a #20 pilot in my WR250 with the #3 slide and a Power Now. It runs even a little rich at my average altitude of 6-7000'. At my base altitude of 4000' and cool temps it is perfect. I would try the #25 pilot. Just be cautious initially.
Stock my 07 came with a 15 pilot, 61 needle, #3 slide but i think that jetting is based on having the throttle stop left in.
I took the stop out and put the 60 needle in, the 35 pilot and put a #4 slide in seems to run fine, never fowled a plug.
In the summer i will run a 30 pilot and play with the needle, some guys up country 2500 to 3000ft are running 27.5 pilots
From Mukuni rep....check float with carb at 45 degress not to compress spring and a TMX38-2, or -5 that is 6-7mm height where the other TMX/TMS carbs are 18-22mm height from base of carb.
My 02 WR250 was fouling plugs like crazy...went down to 25 pilot with no real effect & had to go out 2.5-3 turns. Checked my float...was 14mm....adjusted to 20mm and now I have gone back to a 30 pilot with 1.5 turns out. Float height makes a difference--plus no overflow while bike is sitting which was a pain.
Ok, so the TMX on a Husky, the height is 18-22mm?
Is that from base of carb to the top of float?
Thanks photos helped. I did the float level with the carby flat I will re-do it with 45 angle and measure it... !!Thanks.....
just got back from a ride. And no fouled plugs, the plug is nice and brown, and the bike rips!!! My float level was way out......
I have a FMF gnarly pipe that I would like to put on, would I have to change jetting? Generally would you go richer or leaner with jetting for an aftermarket pipe??
#4 slide PJ:27.5 Main:390 Needle:60 3rd clip
Thanks L
Am hoping you have a typo moment there in your post with a 290 main but meant a 390 cause That is WAAAAAYYYYY lean my friend. Hoping it was the float and a smaller pilot that fixed it. The TMX is lateley been a victim of poor quality control and float settings have been bad from the factory.
Was a Typo 390 main, and that bike was set up by me dealer he did not check the float level,they mainly sell Husqvarna power equipment and are looking for a bike mechanic so I will let them off....
Good to hear it! Now remember, you are your own mechanic until you find one so, to use a race day expression when something breaks, "who's your mechanic?" often turns to a emabarrassing moment for all of us when asked by others. We are here to help so until you find a mechanic, ride and stay in touch!
  • Similar Content
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By Mike Michel's
       Would anybody know how many watts my 99 TE 410 stator
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
    • By Ride
      ...thought this might be fun as i see a lot of older guys riding Huskys on TT. I'll start...
      41 years old - 93 TC610/99 WR250/02 WR250/04 TE450/04 CR125/06 TC250 (on the way)
