05 Exaust line up ?
Hi Guys, I purchased a supposed 2005 R can for my 2005 X..the mid support does not line up. It is off by 1/4". evrything else lines up perfect. I am thinking that the Can is actually from a later year..What do you think ?
Might have to drill out the top mount a little on the can to make it fit. I have not heard of anyone else having to do this though., Maybe its bent a hair, dont really look like it but possible, could be wrong year
thats an 06 or 07 , the 05 fits perfect
Hi Scoot, thanks for the quick reply. I thought of doing that, but even with the top bolt out...I can't move the slip on forward. It is tight against the head pipe. I dont want to force it, as it will stress the cylinder flange.
Agreed
  • Similar Content
    • By TheVolta
      New bike is confirmed, your welcome.
    • By DanielX450
      Hey guys I could really use some help. I bought a 2005 CRF 450x that has an aftermarket air filter, full FMF exhaust system (pipe and header), removed backfire screen, and removed air snorkel. Bike idles and starts just fine, but when I hold the throttle anywhere from barely at all to about 1/2 it bogs, wants to die, and backfires. Seems like lean running conditions to me because if i leave the choke on the problem mostly goes away. Additionally, if i move the air screw out almost all the way (to the point where it could vibrate off), it seems to clean up a little bit. I am trying to determine whether bigger jet(s) would fix it or if its something else. My dad thought it might be the float level, but I'm really not sure. Thanks in advance for your help!
    • By pro dirt
      hi, I'm buying a crf450x and this is the first 450x I'm gonna own but i was a bit confused on one of the pictures. i checked on other crf450x pictures and could not find this on any of the others. There is a gap right below the air filter and above the swingarm and I was wondering if it was normal.
      Thanks!!!
    • By David Rediger
      I have a 05 CRF450X that was just rebuilt that is not starting via its electric start. I can start it with the kick starter as well as a rolling start down a hill though. Once started it seems to run just fine. I have it at a bike shop right now and they are stumped as well. So far I know the battery has been tested/replaced, the carb has been cleaned, jetting is good, and they have also tested the starter motor and things all look okay. Any ideas where to look next?
