Which shims would I need? Please.
Ok to start with I know I need a valve job,ok we got that out of the way so now you dont need to tell me I am wasting my time by shimming the valves.
Ok on my left intake I have a #155 shim and the clearence is at .002 so which one would I need for that one?
Ok on the right intake valve the shim is a 165 and the clearence is at .004 so which one would I need for that one.
I know I need .006 on each valve,the shim chart confuses me,I dont want to get the wrong shims so I figured I would come on here and ask,since they sell them in MM sizes which one would I need in the metric size
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
Thanks,Doug
Your right intake will be perfectly fine at .04 I have been running both intakes there foe well over 100 hours with no problems. Lots of people on here run .04 as it is easier on the valves
yes i do. I am going to be getting my head rebuilt next month. but my bike is an 03 with well over 200 hours on it. My valves are starting to go so its getting a complete rebuild, New piston, crank, bearings, seals, ect.
You should pick up a 1.50 while your at it.
