KLX 300 rear suspension
Ive been having trouble with my rear shock.already did the forks with new springs and valves.someone told me that i don't have to do the rear.but the bike doesn't feel right.
The rear linkage on these bikes sucks. No matter what you do for valving it will just be a band aid for the poor motion ratio of the linkage.
See this thread.
so what could i do to fix the problem?
  • Similar Content
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By TheLastByte
      I'm aware the late model 600r's and 650ls are more or less identical, but I wanted to double check before buying.
    • By Chris Kendrix
      New to dirt bike riding and need to service forks and replace fork seals. I have air bleeders buttons on my fork caps. To use the fork cap tool I'll need remove them when I tighten down the cap to the damper assembly. My question is will I have a problem with oil trying to come out the air bleed or air getting in when I have them out reassembling the damper together. Or do I need to buy oem air bleed screws.
      Thanks
    • By 7Fourteen
      Hey, got a 2014 rmz250 with SFF forks, standard springs, 1.0kg/mm in the forks, 5.5 kg/mm in the shock.
      Weighing in at a whole 155lbs without gear and running at an intermediate/B class mid to back pack pace I need this bike to become much more comfortable.
      Race Tech recommends:
      Fork: - 0.88kg/mm
      Shock: -  5.3kg/mm
      Race Tech appears to be a very reputable company and I apologize for questioning their knowledge but I am simply curious. For those who have used their calculator how accurate were their recommended rates.
      Fork: - 0.88kg/mm My main question for the fork is that their recommended rate seems like a drastic jump in fork spring rate. Maybe this is normal because their is only one spring up front?
      shock: - 5.4kg/mm or 5.2kg/mm are the springs available for the shock. Does one spring rate on the shock make that much of a difference?
      Currently with 107mm race sag which is what I find comfortable on this setup, I have 52mm of static sag (Not good, Too stiff) My main question for the shock would be if there is any way to know the amount of change in static sag from one spring rate to another. (5.5 to 5.4.. would that be enough to make the static 35mm. or would a 5.2 be better)
      What is everyone running for spring rate to make the suspension bearable?
