jetting carbie problem SM
I have an 06 SM610 and just love the bike - except for the stutters it gets sitting on a constant speed (not under load). It feels like the engine is missing. I have had the bike to a specialist high performance motorcycle tuner and after $150 still no real improvement. He played around with needle positioning etc.
Does anyone know of a solution ie do I change the jets and needle or what? Any advice or help would be greatly appreciated. Awesome bike I gotta tell ya!
JD jet kit from a 510, CR8EIX spark plug, disconnect the TPS and it should disappear, expect an increase in power and smoothness too. Good luck!
My guess would be your stuttering is about 1/4 of WOT.
In any case hold the throttle at the position where it is stuttering then pull the choke out a bit and see if that helps or makes it worse. Then push in the choke and pull out the hot start a bit to see if that makes it better or worse.
Then post up what you found out.
My guess would be you need a needle with more taper and the JD kit is a simple solution for that. I have never unplugged a TPS.
The 610 studder is a well known and easily fixed phenom, involves the tune in the CDI for EPA. Simple jetting will not cure it, might mask it but its in the ignition curve too. I could dial mine up at 4500-5000 like clockwork. I jetted till I was bluefaced then, by an act of desperation, I unplugged my TPS, near cured it, CR8EIX was the final nail in the studder coffin. Good luck!
At the risk of ridicule what is TPS and how do you disconnect it? (Also Coffee - what is "WOT"!)
What are the implications (good and bad) of disconnecting the TPS!
Thanks for the help so far - much appreciated.
WOT is wide open throttle, the TPS is the electrical connection on the carb that feeds it the Throttle Position Sensor, (TPS) info for the CDI to adjust its ingition curve, in the 610s case, for EPA compliance. Disable it and it goes to a base curve that is rider friendly, no lean stutter for a EPA driveby. Just unplug it at the harness above the carb IIRC. The Iridium plug will clean it up completely with the aforementioned mods! Enjoy!
Thanks for this advice! Much appreciated so will make these mods to my SM and see how it goes. I am very interested to see what effect it has. Thanks again. Just demonstrates to me the power of this forum!!!!!
good to see another from oz with good taste.
if youre in Sydney , take it to Michael Noble ( MJN Repairs) Emu Plains. He does mainly Huskies , and absolutely knows them backwards. My 07 didnt stutter but he changed the plug to the iridium ( without asking) and rejetted for the Barrett can i put on. By the way that's the first mod you should do- it's even quiter than stock. Our bikes are jetted a bit different to the US ones( I think) and ours dont have all the pollution spaghetti theirs have- lucky us.
good choice!
I posted the word "carby" on a US vehicle forum and got pasted...
The most repeated phrase was "put another shrimp on the barbie...", but then again we could go on about the Seppos bastardisation of the Kweens English...but we won't.....don't want to start a flame war......:applause:
The server his hating me tonight. Tried twice to post and it had logged me out.
Does the stutter come and go?
I've tried the TPS, JD kit, and plug. No dice, and plenty of others that I have spoken with that had the intermittent problem said those solutions failed them.
I'm in Brisbane so can't get to the dude in Sydney which is a bummer. I have had a performance tuner play with it on his dyno and it is considerably better. Good enough to live with no worries but if I can get it perfect I would prefer that - you know what I mean! The studder is pretty much there all the time but under very specific conditions ie usually in 5th at a constant 80kmh or 4th at a constant 70 kmh. I have sourced an iridium plug as per an earlier post and will try that and disconnecting the TPS tomorrow afternoon (after I have a fang up through some local twisties - the Husky SM rules I reckon even if it has a tiny little fuelling issue (no big deal really!)) Huskies are awesome bikes!!!!!
Have you adjusted the jetting kit, (esp. the needle up or down) to fine tune? Your the first I've heard of who couldn't dial it out. You might need to adjust due to weather, altitude or even the fuel you use. Our NJ fuel changed in 06 and gave me & friends grief. Bikes felt lean but needed leaner setting to run without surging. You gotta adjust to your condition, one size dosen't fit all.
Well folks it is all fixed!!!!!!!!!
I'm stoked!!
Did what JJM525 said (and a few others) ie remover the TPS and install an iridium plug and man what a difference. It is bloody awesome. Smooth, powerful, doesn't feel like it is "nervous" - just brilliant. Thanks guys it was the only concern I had with the Husky and it was starting to piss me off! All is good now! Thanks JJM525 and others for your help!
Hay coffee thats a good trick im still playing with mine, so choke will richen it up,walm start lean it yea. could save a lot of spanner work people.:banghead:
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By Dean.b
      Long story short I bought this 2011 WR300. The thing is mint, looks brand spanking new. The thing ran like a top, but only had one problem, a low idle. I was to lazy to fix it and just dealt with the fact that I always needed to keep a little bit on the throttle. My third ride on it, I took it to the florence dunes and the top end burnt up. I have just finished fixing it and all I need to do is break it in. I need to adjust the idle first though, and don't know if I'll have the idle too high until it starts. I don't want to hurt the motor on a fresh rebuild and want some opinions on what to do. Do you think it will be fine? How many turns out should I set the carb just to be safe?
      Any response helps
      -Dean
    • By dorilabo
      #Husqvarna
      #CR125
      #2-Stroke
      #Maintenance
      #Advice
    • By motoxtremist
      Just bought a used 2017 Husqvarna FC450. It's my 1st EFI bike so I'm hoping someone can help me out with this issue.
      After starting the bike cold and idling for about a minute or two, it blows a puff of blue smoke from the exhaust pipe if I roll the throttle. It also does this if I stop to talk to a riding buddy on a trail or on the side of the track, let it idle, and then start out on track again. After revving it once the blue smoke is gone but riding buds have told me they smell and occasionally see a puff of blue smoke when following me - not a constant stream just a puff and then it's gone for a while. I'm talking to myself over trying to locate the cause of this as a leak-down test shows no issue.
      Bike history
      Bought used with 70 hours on it.
      Original owner had an FMF header and tailpipe on it which he kept. He sold it to me with the stock pipe. He never had it remapped for the FMF pipe
      Started it's life in Atlanta GA
      Now mostly ridden at sea level
      He told me he used mineral-based 10w-40 Yamalube oil. The manual calls for 10w-50 Ester-based synthetic - which the bike is now running.
      This is what I've tried so far:
      Leak-down test produced only a 3-5% loss.
      No bubbles in the coolant with the cap off
      No air leak at the exhaust pipe
      No leak at intake
      Barely, barely noticeable hiss when I remove the oil fill cap - but again not enough to lose any more than 5% pressure during the leak-down test.
      Wouldn't matter but checked the valve clearances while the valve cover was off. They were in spec.
      No loss of power
      No milky engine oil from a coolant leak
      No loss of engine oil as seen at the engine oil level window - never needed to add oil between changes
      Talked to someone who builds motors for a living and he said "all KTM/Husqvarna's do it especially when cold because the EFI delivers more fuel on startup as opposed to running at operating temperature". I guess I can see that but why does the bike blow blue smoke at operating temperature then if I pull off the trail or track for 1 minute to ask one of my riding buds something? I'm not letting it idle for minutes at a time. 1-2 minutes tops. Is this just normal for KTM/Husqvarna/4-stoke racing bikes?? Any help would be greatly appreciated!  Former bikes where 2-strokes (CR250, RM125) and a 1993 DR350 which I could've let idle for 20 minutes an not seen blue smoke - but that was a carbed bike. I've always known if a 4-stroke is smoking blue it's burning oil and you shouldn't keep riding it. So I'm a bit concerned about whipping it around the track or taking it out a few miles on trails.
    • By MotoXRacer_19
      As the title suggests, I've been debating the idea of throwing in a high compression piston. It will bump the compression in my 2014 KTM 350 XC-F from 13.5:1 to 14:1. First and foremost my main question is, because I live under 1000 ft and usually run 97 octane REC gas, will I have to change the fuel I run or not? Also, will I have to change out the cams to aftermarket and re-time the whole motor and ignition? I guess I really don't know what to expect so any advice will definitely help! Attached below is a photo of the bike I plan on putting it in.
