PLEASE will someone help me with my 06 250sxf carberator, UPDATE READ
i recently bought a ktm 250sxf. 3000 dollars. nice, but i got some adjusting to do...
this bike wont start for shnit. 60 some kicks and if im lucky it will start. CANT USE THE CHOKE...dont work, need to figure that out. bike farts and backfires like crazy.
i need to know how to tune my carb good and im sure TT peeps will help me out.
some info about my carb.
there is a boysen jet kit, but i doubt its right. it feels like the bike runs rich as well.
heres the problem im goin on with
cant use choke until it starts to idle...which thats FORVER AND SOMETIMES IT DONT and after all of that, i lost a good chunk out of my leg...not even kidding, IT HURTS :applause: .
Too make things short
i need someone to help me adjust my carb. and tell me what the hell is a 50 pilot so i can set it to that, i saw in the book the previous owner had it sharpied in.
thank you everone i need the most help i can get. its stuck at a friends and i want it home. I GOT IT RUNNING BUT THE DUMBASS I WAS I WALKED AWAY FROM IT THINKING IT WAS OK. came back started idled for 10 seconds and died and i gave up.
check the valves
Your PILOT jet sounds WAY TOO BIG!!
A 50 pilot is very large for any carb ... and of course your choke will not work if your too rich to start with.
Go and buy a new one for $5 or so .... say a 42 ... or whatever STOCK is.
Drop it in ... 10 minutes later, you'll be rippin'.:applause:
doubt its valves but im going to just in case.
HOW TO I ADJUST IT AND DO IT... it first said 42 pilot in the book. then it had 50 for better starting. and how do i lean it out
You need to find a way to LEAN out your bike to get it home. Screw the fuel screw all the way in .... try your hotstart lever.
in the book it had 40 stock, then 42 pilot in, then 50 pilot in. (better starting)
this guy rode in winter as well dont forget
I think you just answered your own question ... 50 pilot in WINTER would make sense. Not if its warm out though.
Go and hold it your HOT START lever and try to get the bike running at least
HAHA SUPERVOKES U ARE THE MAN.! but now...how the hell am i gonna fix this
You need to get your bike home and put in a smaller PILOT jet.
A 50 pilot would be used ONLY for cold weather riding.
Drop in a 42, and you will be good again.
Good luck guy
...and hold that hotstart lever in to get your bike running.
thanks i appreciate it.
now anyone, how do i install new jets
Can someone help me on finding out then how do i take out the jets and put new ones in. ive decided to get a new jet kit for this.
Remove the carb from the bike, and remove the float bowl from the bottom of the carb. The main jet will be in the center of the carb on the bottom, and the pilot jet will be offset slightly to the front/side. Simply unscrew it with a 6mm socket and screw the new pilot jet in.
Before you re-install the carb, turn the fuel screw all the way in (it's the tiny screw in the tunnel on the bottom of the carb near the front), and turn it back out 2 turns for a starting point.
Also, you should get out your manual and go through the procedure for adjusting your accelerator pump before re-installing the carb.
A good carb cleaning while it's off the bike also wouldn't hurt anything.
yea, my honda has a jd and the ktm i recently got has a boysen and i think its junk. there is a 50 pilot in there and its causing the bike to run way to rich. and jd is the best kit out there i personally think. it starts up my honda in 2 kicks even on bad valves...
42 pilot AND check your compression! THe rings in that model have a 40 hour life expectancy and you can kick you brains out trying to start an engine thats down on compression!
no its jets. i know it.
ALRIGHT. got the carb out checked everything and he it goes
main jet 172.
idle jet 42 (normal
starter jet 85 (normal
fuel screw, felt like to many turns out.
now he it is
main jet 170
and i put in an easy fuel adjusting screw and set it out to 2.
my question is what made the bike run to rich and not start.
Too many turns out on the fuel screw will certainly do it.
i thought so.
and pj is also called slow jet?
  • Similar Content
    • By whiteduke13
      Bought a 1999 Yamaha xt350 couple months ago from a guy that hadn't started it since 2011. I started off removing majority of the big chucks of rust from the tank via bolts/vinegar, and replaced the fuel line, and inline filter with a see through material. Additionally I had the carburetor cleaned by a local shop. The shop messed something up and now the choke is stuck in the closed position, but the bike ran fine for two days in a row (about 2 hours each day). A week later it started dying while riding and I believe its because fuel isn't making it to the carb. I've checked the screens on the petcock, and replaced the tubing and filter to the carb. Before having the carb cleaned the inline filter would completely fill up before starting the bike but now only fills to a third of the way. The inline filter goes dry when running thus the motion fuel isn't making it to the carb. Flow through the fuel line is at a trickle when connected to carb but gushes when fed to a gas can. Any ideas to why I'm not getting flow???
    • By Kawasuzuki456
      So I have an 03 rm 125 and I’m having a problem with my jetting. My original 460 main jet that came out of the carb is huge and unlike any jet I’ve seen before. I also ordered a mikuni genuine main jet off of eBay and went to go put it in the carb (440 main) and it’s way too small. Not sure what to do.
    • By AKrazy
      Hello kids,
      Looking to get my second dual sport. Ive been riding for 3 years on my DR200. I mostly prefer single track and technical riding.
      I recently test rode the DRZ on dirt. I liked the extra grunt, but found it too tall for my legs and too top heavy for my riding style.
      Anyway, I like what I've read about the KLX250's suspension and aftermarket mods. I see "easy install" kits and directions all over, but no information as to how the 2018 kid's EFI will change installing these kits.
      Will it require an aftermarket EFI? Or possibly even a carb swap kit?
