quick question about piston/fuel
With the JE 13.1:1 piston...can I still get away with running 91 octane or would I have to run race fuel ?
i haven't done it yet just looking at the possibility of using that piston. I can get a LA Sleeve/Wiseco 453 kit with that piston super cheap. I realize not to use an iron sleeve...I would send my spare cylinder out to be bored and plated...what cams would you suggest using with this setup ?
i suggest avoiding bores over 94mm if you can.the chance of head gasket sealling problems goes up when you go over.
what bike do you have?what type of riding?
what piston would you recommend ? I know alot of people have used wisecos...i know with 2stroke snowmobiles those wiseco pistons are a POS so i'm leary even with my 4stroke...
does the hotcams stage 1 come with intake and exhaust? i have an FCR 39...you told me a while back it was from an 01 YZ426 from some numbers i had off the carb...i also have a twobros slip-on...the bike was 6 weeks old when i bought it but already had that pipe on it...all I can say is that it's LOUD. I know a few people with yosh full systems with no baffles and you can't even hear theirs when mine is running. It does get a bit annoying i have to admit.
I hope I'm not hijacking the thread, just clarifying -
I have an '06 DRZ SM - FCR and Yoshi Ti
I like to do mods as money comes in
Is it okay to just to cams
Later to do big bore and base gasket
Sometime after that do the stroker
Sometime after that the headwork
Is it better to save up and do it all at the same time?
I hear such great things about you Eddie, but at the same time, I am ignorant. What is the benefit of sending my engine to you vs. my local shop doing it vs. my trying to do it myself?
Thanks in advance,
Branden
Also, if a big bore and stroker are the ultimate long term goal - is there any sense in putting in hotcams now if I intend to do the big bore and stroker - which as I understand it, the RHC cams and headwork are recommended?
Thanks in advance,
Branden
by doing it this way you are talking about alot of redundant labor.if you are paying someone to do this,it will cost you way more money in the end.
whether or not you or a local shop are capable really depends on what the ulimate goal is for the motor.
just installing cams or a big bore is pretty straight forward.the stroker set ups are not and imho are not for novice engine builders and that includes most local shops.
you need to decide what you want to do for a motor before buying parts.
the hotcams are fine for stock motors or big bore at a maximum.they are not suitable for the strokers.
RHC cams are needed for the stroker motors to run at full potential.
head porting is optional and does require over size intake valves.
no matter what,you need to repalce the valves and springs at some point for reliability reasons.
so you figure that 453 piston is no good then ? i bought a kit for $100.00. I was just going to use the piston and gaskets but I guess i'll just put it on ebay instead...
its just as i stated.the risk of head gasket sealing issues goes up when over 94mm.
if you take the proper precautions,it shoudl be fine.i use them occasionally although i try to avoid it.
what do you use to seal the head gasket? I've seen people use spray on gasket sealer...I have a spare cylinder so I guess it won't hurt to try this kit out. Do you think there is much difference in power with the 453 vs. a 436 or 440 kit?
copper coat the head gasket,42ft/lbs on the head bolts.
its a minimal power difference.
if you use that piston and its 13.5 to comp i would add a extra base gasket.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
