Ticking when hot update.....
Well, i finally got around to checking the valve clearances today.
The intake left and right were both 0.10 and exhaust left and right were both 0.20. I know this is on the minimum tight side which i hope is ok? but as they expand as they get hotter i cant see that its the valves causing the ticking.
I also checked the ACCT which is in gread order as well as the cam chain which seems to be adjusted nicely and correctly.
So, after reassembling i fired her up and all sounds perfect until after a 5 mile blast to get things nice and hot and hey presto, ticking like a bomb.
What sould i check next guys?
i bought feeler gauges this weekend. will be checking up on the clearance of my 05 sm sometime soon. just a bit of ticking. only when hot.
If you mean "like a bomb" = loud then speak to a pro wrench.
i dont know what to check next...
After all this ticking talk I got mine good and hot and stopped at the dealer to have a mechanic listen to it. I trust them and they've done a good job for me in the past. He said it was all normal and sounded fine-just the regular sound of the valves opening & closing on a four-stroker.
He agreed that slightly loose is better than slightly tight and that a little looseness will not cause catastrophic failure whehreas too tight possibly could.
Finally, he said if it was far enough out of spec on the loose side you'd know it cause it would be distinctly louder and you'd lose power.
I'd say get a pro to listen to it/check it and if they say its OK, then ride.
My friend had the same kind of problem on his SV650.
Removed the ACCT and reset it, and it stopped the ticking for a few miles. Then it was right back again. I personally thought it was the ACCT and cam chain.
ACCT's (the modern ones) over tension the chain as they are sprung loaded so constantly adding more tension. Most of the time more than you need.
Vavle clearance sounds okay ish...
Depends on how you mean when you say the intakes were 0.1
Was the 0.1 a go and the 0.2 a no go? Same for the exhaust (with 0.2 and 0.3) ?
If so thats fine! and they are perfectly in spec.
If i was you i would invest in an MCCT and avoid the potential destruction the ACCT could cause.
Maybe replacing the cam chain at the same time wouldnt harm!
Well the valve clearance on the intake was a nice snug 0.10 A 0.15 would not fit at all and the exhaust was nice and snug at 0.2 and 0.25 would not fit. Well i say snug, i mean just slipped in nice and easy.
As for the ACCT i think changing to a MCCT is a good idea but dont get me wrong, i dont know much about engines but surely as the ACCT spring gets older the tension would decrease? And i still dont see how the tensioner and chain could only make noise on a hot engine?
P.S i did reset the tensioner on inspection and unfortunately that made no difference.
Not!....The spring in the ACCT is not going to loose tension! The racheting design of the current ACCT will apply constant tension to your chain....stretching the chain over time.....some people have had their chains reach max stretch after 2500-3000 miles while others get 10-15k out of theirs.
I installed a MCCT after about 100 miles...adjusted once and have not touched since....2500 miles logged
agreed, if you had the opposte loose end spec I'd expect some tick.
The weather is cold right now, it may be an thick oil thing
One time I ran a 20 w50 in mild temps, my bike quacked like a duck, clack clack clack .
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
