project bikes...lets see em
post any project bikes or hybrid bikes..thanks
here is my 1991 rm 125: it has a 2006 rm-250 motor, with 2006 dr-z 400 tank, seat, radiators,rad shrouds, and forks/front wheel,
and rm-z 450 front and rear fenders, this thread has a lot more pics and details of the project
http://www.thumpertalk.com/forum/showthread.php?t=606585
why the drz forks? just wondering? and it might be a good idea to squirt some wd40 and cover up that cylinder if there is no head on it.
well the dr-z forks made it easier to just use the electronic dr-z speedo/odo with the dr-z front wheel, and they are better than the stock '91 forks ever were.
and these pics are only of the "mock-up" phase so i just set the cylinder on there to mock-up the exhaust, the bike is already torn apart for the 10th time in the garage, with the motor wrapped up in a garbage bag
oh i see:thumbsup: looks like a prety sweet projecet. it will be a fun bike. are the drz forks going to stay on there?
oh yeah they are there to stay. in fact i had been running them for months with the original 125, long before i started this project, they are what inspired the project you know......"it already has 06 dr-z forks, what else can i fit on it?"
Just where a suzuki motor should be!
:applause:
:applause:
you are totally right, suzuki is the only brand worth taking care of
so how do those forks feel when they are not on a drz? i have ridden my bros drz 400s offroad and its a pile, i mean its ok but it just sucks offroad, but im assuming that drz forks on a lighter 125 they prolly are prety decent?
One of mine started off as this, a 1987 CR500....
Then I got a 2000 roller and swapped the motor into it and parted the rest of the 87...
Then the bottom end blew and I put in the bottom end from this 1989 and parted the rest....
And then this 2001 ported top end...
The I added the NOS....
Ended up as a 2000 roller with a 1989 bottom end and a 2001 top end :applause:
My other bike started life as another 1987 CR500
The got hold of a 1997 CR250 roller and added the motor from the 500
Then got new plastics
You have to be kidding, as if a 500 wasn't enough, you added nitrous? You're a madman! :)
the dry weight of the 1991 rm 125 is 191 lbs, the dr-z "s": 291 lbs, i didn't have to change a thing, that 100lbs lighter makes the fork operation perfect, in fact i called racetech and they said that for a 191 lb 125 i wouldn't even need to change the oil thickness....its almost like those forks were made for the 125. that is why the dr-z forks leave so much to be desired, it is sprung and valved for a 100lb lighter bike. but it makes for a smooth highway ride.
yeah thats kinda what i was figurin. that will be a fun bike with a 250 mill, and :applause: on the rmz plastic looks good.
umm do you really need n2o on a five hundo? good looken 500s though!
my RM-Z 150L :applause:
it once was a completely stock drz125L when i first got it....
...but $3,000 later...(yeah it adds up!!!)
>Chassis/Controls:
BBR Frame Cradle
Gusseted and welded frame to hold up my fat a$$
Graphics (eh...:) )
BBR gold rims/ Prowheel spokes
Michelin Starcross MS2
IMS superstock pegs
Protaper Top clamp
Protapers (pastrana FMX bend)
Custom tall seat
Moose shorty levers
Goodridge Braided steel frt. Brake line
UFO fork guards
KX front axle
Tusk gas cap (bling :cry: )
dr200 direct shifter
>Suspension:
KX 85 front forks
Cannon Racecraft frt. .38 springs
CR 85 shock, freshly rebuilt/recharged
Motion Pro Fork bleeders
>motor/intake:
Wiseco 143cc 11:1 kit (4mm overbore)
Hotcams stage 1
EBC clutch
procycle oversized valves
26mm vm26 mikuni carb
ProCircuit T-4 exhaust
Lightened flywheel
Ported and polished
Intake opened up and No Toil filter
Moose sprockets
Graphics (eh...:applause: )
once i get the frame sand-blasted and re-coated, and i decide on some side-panels, i will be able to decide on some graphics?
what side panels do you guys think i should go with on my project? what graphics? should i have custom graphics made that say: "D-RM-Z 250" ? should i even call it that? what do you guys think i should call it?
why the heck would you put nos on a 500? nobody could ever use the power of a stock one. Some good projects here.
Dune racing probably.
on trails or mx its not nessecary but on some big dune climbs you can use all the power you can get.
2 1970 CT70s and a 1982 husky 250CR.
