Few questions from a new owner 2000 yz 125
I searched but there is so much info on here i couldnt find my answers haha
First since my 10th digit in the vin is Y i have determined i have a 2000 yz125 not a 99 like i thought i was buying haha not a bad surprise i guess
What years are the same as my 2000? mainly i need a new head and piston and want to make sure it will work with my connecting rod and bottom end.
Stock gearing and other specs would be nice to have as well.
Also things like fork seals, full rebuild kit, plastics and gas tank. What years are compatible? Thanks in advance:cheers:
96-01 the plastics and graphics will interchange..250 stuff like plastics and graphics will also fit if its the same years..um..not sure about the head,and piston..its possiable tho..i think the sprockets will work..but other than those few things im not sure.
if you go to the yamaha website, they have a parts catalog where u can check to see what parts interchange with other years. most of the time on different year bikes the first 3 to 4 digits will be different, so just go by the last digits in the part #
Well i have ordered a bunch of stuff but i am still stuck on the cylinder head.
Part numbers are different for every year of cylinder, but i know they aren't all different. If anyone knows what cylinders are the same as a 2000 that would be awesome
Also the local shop is telling me they cant bore this type of cylinder out, mentioned because of the type and the powervalves?
Can these be bored out or must they be resleeved
i thought mine would have to be resleeved when i blew mine up..but we took it to my shop and they bored my cylinder for me.
if the cylinder is not too scratched it can just be re-honed...check yamaha of troys website, they have brand new cylinders for $236 or around there. what does the part number on the side of the cylinder say?
  • Similar Content
    • By faizakhtar125
      Hey guys I read an article saying that the 01 YZ125 has six gears. But other people are saying that it's 5. How many gears does it have? Just asking. Thanks.
    • By idratherberiding
      2006 YZ 250.. The manual calls for 10w30 (yamalube 4 stroke oil), can I use 10w50 (Motul semi sythetic 4 stroke oil) ??   I bought the bike, want to change the gear oil before I ride tomorrow but all I have at the moment is the Motul 10w50  semi synth.  Is that oil going to be too thick compared to the 10w30 or will it be fine..  Thanks
    • By faizakhtar125
      Hey guys I just wanted to show off my bike and show it to the world lol  What is your opinion on it. God or bad, please be honest. I am open to all comments and suggestions. Any upgrades I should do to make it look better and/or faster?
    • By Allooushh
      I bought a YZ250F yesterday and the previous owner said apparently it runs but they weren’t strong enough to kick it. I couldn’t kick while there so I took their word for it and bought it. I’ve been trying to get it to fire all day today, there are 2 chokes and I’m unsure if the air mixture is correct, so would be nice to know what I should do, it’s hard to adjust the air screw when the bike won’t even run. I noticed the spark is kinda low, I don’t know if it’s normally supposed to be like that or not. I can see a blue spark but it is very small and crappy, I’ve had thumpstars that generated stronger spark, I changed the plug it’s still the same, so maybe could be an electrical problem, the only ground connection I could find was for the ignition lead which I filed down to bare metal so I’m pretty sure that connection is good. Anything else I’m missing? It’s very hard to kick and I can feel the compression out of the exhaust so I don’t think compression is the issue.Just wanna know what I should do, haven’t owned a yz before so I could be not using the choke right or something. Thanks
