Fork sag guidlines?
I've got a TE610. When holding the front brake and stepping on the footpeg, the front compresses "somewhat" less than the rear. Sag is 40 mm static, and 60 mm rider. I weigh about 175 with gear. What does this tell me about the spring?
I've read in a few places rider fork sag should be 25% of travel, which would be about 77.5 mm...but then i'm also reading that a lot of folks run significantly less sag than that...especially on mx bikes.
Does the fact that this is a 320 lb bike make any difference in the guidelines? The bike gets used for a bit of everything, from tight woods to jumps to street riding.
thanks in advance for your replies.
First of all you have to know what the manufacturer recomends for race and static sag. Then you use your measurements to decide wether you have the right springs or not. The weight of your bike is irrelevant as the manufacturer takes this into consideration when designing the bike.
Your static sag looks pretty good but the rider sag is too high. You want 75-80mm rider sag. 35-45mm static sag. If you don't have enough sag then your bike will have problems setting up for tight turns in the woods. Check and see if you have preload spacers inside the forks on top of the springs. WP usually has a couple 5mm spacers . I usually end up removing one from each leg. Your Husky probably has 11.8" or 300mm of travel. Seems to be the industry standard today.
Dwight
  • Similar Content
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By TheLastByte
      I'm aware the late model 600r's and 650ls are more or less identical, but I wanted to double check before buying.
    • By Chris Kendrix
      New to dirt bike riding and need to service forks and replace fork seals. I have air bleeders buttons on my fork caps. To use the fork cap tool I'll need remove them when I tighten down the cap to the damper assembly. My question is will I have a problem with oil trying to come out the air bleed or air getting in when I have them out reassembling the damper together. Or do I need to buy oem air bleed screws.
      Thanks
    • By 7Fourteen
      Hey, got a 2014 rmz250 with SFF forks, standard springs, 1.0kg/mm in the forks, 5.5 kg/mm in the shock.
      Weighing in at a whole 155lbs without gear and running at an intermediate/B class mid to back pack pace I need this bike to become much more comfortable.
      Race Tech recommends:
      Fork: - 0.88kg/mm
      Shock: -  5.3kg/mm
      Race Tech appears to be a very reputable company and I apologize for questioning their knowledge but I am simply curious. For those who have used their calculator how accurate were their recommended rates.
      Fork: - 0.88kg/mm My main question for the fork is that their recommended rate seems like a drastic jump in fork spring rate. Maybe this is normal because their is only one spring up front?
      shock: - 5.4kg/mm or 5.2kg/mm are the springs available for the shock. Does one spring rate on the shock make that much of a difference?
      Currently with 107mm race sag which is what I find comfortable on this setup, I have 52mm of static sag (Not good, Too stiff) My main question for the shock would be if there is any way to know the amount of change in static sag from one spring rate to another. (5.5 to 5.4.. would that be enough to make the static 35mm. or would a 5.2 be better)
      What is everyone running for spring rate to make the suspension bearable?
