2007 Wr250f
A little background. I bought my wr for trail use and have found myself more and more enjoying the jumping aspect of dirtbikes. I have been able to jump everything I have tried so far, but sometimes the landings are rough. I know that my suspension is not set up for jumping.
My question is what can I do to my bikes suspension to stiffen it up a little bit to make jumping more comfortable? Will I be able to adjust the stock set up enough to make the changes I want, or will I have to revalve and respring?
Do nothing but change the viscosity of the oil. That will fix three problems - blow-through, bottoming and the rough-chatty ride
Then follow up by fine tuning the oil level to suit the needs of ride height and bottoming protection.
If that doesn't cut it, you'll have to advance to a re-valve.
:applause:
  • Similar Content
    • By Wade Beall
      I’m looking for stock rear suspension link. I bought my 2007 xr650l with a lowering link on it and I want to go back to stock height.
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Alex Wren
      I recently bought 1988 xr200r forks to go on my 2002 xr200r (got them revalved for my weight and riding style), and I only bought the fork tubes. As I was trying to put them on l, I realized that they do not fit in the triple clamps of the ‘02 xr. What do I do? Please help!
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
