Awesome Efi - 08 Te 510
Yesterday I entered the Innot Hot Springs Pony Express race, on Rhonda my new 08 TE510, along with another 146 riders. We found out that the track consisted of a 13 km loop on a cattle station that was very sandy & mixed with black soil, quite a few creek crossings with drop offs on entry & steep slippery exits. The only problem was, that over 100 mm (4“) of rain fell the night before the race, creating havoc out on the track.
Not wanting to get too excited & head off early I opted to take a back seat & wait my turn. Once into the sighting lap I realised my mistake & wished that I’d headed off earlier, the track consisted of deep, sloppy, fine sand/black soil that the earlier riders had churned up. The wheel tracks looked good until you were in them, they were stopping bikes in their tracks & you had to physically pull them out. In many instances the bikes needed two or more people to help remove them from the sticky sloppy bog. It was so sticky in places that bikes would stall when trying to get the rear wheel to spin.
After getting stuck up to the axles several times my self, I resorted to grabbing the handle bars, pulling the bike over until it was flat on the ground, taking hold of the fantastic hand hold of the side plate & dragging the rear of the bike sideways out of the sand/mud & then drag the out front wheel. I would then stand her up jump on, then just hit the button for a trouble free start time after time after time again. I have to say how impressed I was with the EFI, flawless every time I started & in these wet conditions. Other riders were using the same pull it to the ground & drag it out technique but were having a hell of a time trying to get their bikes started again after. I was chuckling to my self as I smelt the spilled fuel & I watched the frustration of the other riders, cursing & swearing whilst trying to get their bikes going again, how lucky I was to have the new Husky with the EFI.:cry: I even stalled her on a steep bank on the exit of a deep creek & slid back into the water until the water came up to the seat & my butt. With the engine totally submerged I gave her a kick in the guts & away I went up the bank & on to the next section, as I said earlier VERY impressed with the EFI & the bikes ability to start in these atrocious conditions.:)
Of course when we arrived back at the marshalling tent the red flag was up cancelling the event & after a sighting lap of 2 hours I wasn’t keen to take my new $13000 bike back into those conditions. We won't forget this race for a while, very challenging. Great news for Husqvarna & the new EFI bikes.
Damo.:applause:
Sounds like fun, sorta. It's those kind of events that make for long lasting memories.
Sounds fantastic!
Sighting lap = 1st lap?
Its a lap before the race starts,to familirise yourself to the track,and it sounds like a bike braker.
The EFI is incredible for starting. Just fires up every time. We just went for a 2 day ride at Coffs Harbour n had 300mm in 2 days and its still dusty in Victoria, figure that out. Theres a guy down here playing with a EFI controller to up the horse power. Ive only played with the diagnostic tool from Husky but not up with EFI. It makes TPS adjustment alot easier than with ohms meter but didnt have a workshop manual to check the other adjustments. My mate just done his shock n fitted 5 extra high speed shims to stop the harsh bottoming and softened the initial stroke. Forks just needed a splitter to take the initial harshness out. Gunna have the two WEC Husky factory riders at my place for the Australian four day enduro but I think Obluki will ride a 2 stroke but Meo may be on a 450
They are unbelievable when you hit the water crossings, i agree.
We went to Cathu a couple of weeks back and same - water up to the seat & through it went, Husky & a Gasser made it no worries - Yami 2 smoke didn`t fair so well.:applause:
Atherton Area is bloody horific with heaps of water, sounds like you had fun:confused:
  • Similar Content
    • By 305hestbeck
      So I just sold my bike 2017 TC250 with only 17 hours on it. When it left it was in brand new condition. But 2 days later the engine cases were being split.
      Turns out the Idler gear had snapped off during the new owner’s first ride. Of course I am not paying for the fix as one it is clearly a manufacturing defect. I told him If needed I would help by me claiming it as warranty issue.
      Anyways I did some research and discovered that the KTM/Husky expected a 6x12 to hold the idler gear sys together on 2017.
      Well this seems to be an issue and KTM did fix it for the 2018 models. They actually updated the whole Idler gear sys, but if you still have a 2017 2 stroke the fix before it happens which it could on the first kick would be to replace the bolt with a 6x20.
      You will have to tap the hole for more treads. Actually the 2018 engine case was also updated for this and that’s all they did.
      I own a 2018 TX300 now. One reason why I looked into it.
      Just thought I would share.
    • By Tranos07
      Greetings to everyone. After a lot of searching I finally decided to join this forum in order to finally find a solution to my problem. Here's my story. Bought in a hurry an sm610 2005 (cylinder with the small tensioner) which wouldn't start cold. Only if I connected it to a car battery would it start but not always and not easy. Got a new 14amp battery and nothing. Spark plugs,starting spray etc nothing worked out. If the engine was cold it would start in an instant very very easily. Took it to a mechanic he told me that it had no compression so he grinded the valves. When I got there to take it back he told me that my pick up coil was in bad condition and needed to be replaced in order to start cold. Of course nothing changed after the valve job and after 5 hours of riding(not constant) my new head gasket blew and when I took it apart I found a crack in the water passage on my head right next to the blown up spot on my gasket. I don't know if it was already cracked or if it cracked after gasket blew all I know is that it was tightened properly as I was in front when this happened. I'm just trying to figure out why i can't get it to start cold. All answers are welcome. I had the head fixed and I'm ready to reassemble the engine. Could the pick up coil actually be responsible for this? Another thing I noticed. My tensioner had an apostate welded up to it so i needed a new cam chain as well as a new tensioner. I have these. Could the ruffled chain be in charge? The engine was perfect when hot starting and working like a charm. Please someone help as I'm ready to take the damned thing and throw it into the ocean.
      PS is the pick up coil from an lc4 engine compatible?
    • By birdland101
      Restored 1974 honda xr75 original motor and frame podercoated frame runs, looks, shifts, stops good. top end rebuild many new parts most all honda. email birdland101@hotmail.com.
    • By Jawehangwe
      2017 Husqvarna TX, TE, FE, 125, 250, 300, 350, 450, 501
      Greatly reduced arm pump and fatigue
      Increase rear wheel traction while standing under acceleration
      Create a seat bounce effect when jumping standing up
      Shave seconds off your lap times
      Light weight and adjustable
      Easy to install
    • By MotoXRacer_19
      As I was inspecting my new-to-me bike that I just purchased, I noticed there is a grove on the back side of my front brake rotor that goes completely around it, and you can feel it with your finger nail. I have noticed some poor performance, but I figured it was because of the new pads that the previous owner installed just before I bought it hadn't seated yet. However, I've ridden a couple times and it doesn't seem to get much better, if any better at all. Is that enough to explain why when I pull in the brake as hard as I can, it only slows me down a little, instead of going into a stoppie and over the bars (as I wish it would)?
      Should I look into buying a brand new rotor?
      I have no pictures of it, I'll try to post some when I can.
