crf 150 or 230f
before i buy my first dirt bike i was choosing between which of these crf 150 or 230f?
well its hard to help you when we dont know what your gona use it for, how tall are you, what experience you have, where you gona ride.
+1
Also is this your first bike? And what kind of riding do you see yourself doing in a year or two?
didnt we answer your questions there.
im 5 7 and its my first bike just going to ride around the yard and maybe take it to some trails
Get the 230 for your height. sit on both bikes, move them around, see if you can pick them with ease.
Get the 50 its great for a yard...
why would he get a 50 for trails.
I love my 50 for trails haha
But in all reality, I'd personally say a 150f..
Just because they are easier to throw around, you'll probably be able to flat foot it, and you shouldn't ever have problems in trails..
The 230 gives you more to grow into, but doesn't leave much room for putting your feet down..
I'm 5'11" and I still find myself in places in the woods, where I can't get my foot down, and I gotta dump it over lol
It all just depends on what YOUR looking for
im going for the 230 because i found some empty lots that are very large which is plenty of room for a 230
He wants to ride in the yard....
Are you going for stunt riding? onroad or offroad racing? Or just playing around in everything (woods/parkinglot/yard?)
If your going for stunting, I'd recommend the 150f.. 230 is just too big for the power it has, if you want a full sized bike like the 230 for stunting, IMO get a bigger bike like a 250f/450r.. Or get a 150f to have a mid sized stunt bike..
If your wanting to go fast in a parkinglot/fields/track, definitely get a 230
If your looking to do pretty much only trail riding, I'd say the 150f..
But for all around riding, I'd say 230.. That way you can have more power in the open
Thats my 2 cents :applause::)
he is also doing trails.
little bikes are fun as hell in the woods...
or before 2 strokes die buy a yz 85
an 85 is about the same size as the 150 but with much more power, lighter, and a better suspension
an 85 expert (bigwheel version) is about the same size (seat hight) as the 230 but lighter, better suspended and a bit more acceleration
an 85 might be a little too much for a brand new beginner but you could get use to it :applause:
if you do get an 85 take it easy until you get used to it.
IMO I don't think a 2 stroke would be as great for woods riding..
No low end torque, doesn't like to lug down in the woods well..
150/230f are GREAT for trail riding (hence why they are called trail bikes)
ALL kinds of low end torque.. Bikes like the 150r dream they had as much torque under 5k rpm as the 230 :applause::)
But ya a 85 definitely is faster, and better at hitting jumps.. BUt personally I'd hate one for trail riding
I love being able to come around a corner on my 150f, in 2dn or 4th gear, and still be able to pull away from the corner :cry:
I love being able to come around a corner on my 150f, in 2dn or 4th gear, and still be able to pull away from the corner :eek:
Couldnt have summed it up better than that :banghead::foul::eek::cry:
  • Similar Content
    • By H0ndaHunter
      Hello all,
      I have a 2005 crf230f im wanting to modify my bike as best as possible for a sumo style bike. My first thought was an engine swap.
      Has anyone done an engine swap on this bike before? If noone has what engine would be the best fit to do so?
      The 230cc engine desnt have enough umph to really be a daily driving unless taking backstreets all the way to work so im trying to see what i can do to make it have the umph.
      Some of the mods ive done include the airbox mod, a lighting kit, sprocket change (i believe i have a 42 and 13 but cant rememebr), and a jetting mod where my dad took the stock jets and drilled it out just significantly enough to make her kick as much as she can.
      Im looking at doing handlebar risers, an airbox mod on the right side of the bike for even more airflow, cr500 shock if possible.
      I am absolutely in love with the turning radius and nimbleness this bike has. I have ridden my dads BRP and my brothers crf450r and they just cant skirt around the world like my bike can so im trying to get the power (hopefully) of a bigger bike in the body of my bike.
      Im not looking to have to completely tear the bike down to modify the bike, but if need i can make it happen. Before i am forced to modify the frame to accept another engine, are there any straight swaps that can happen? Are there any other performance mods that can be done to get that speed a little higher without sacrificing too much reliability?
    • By JMD984
      I have an 03 CRF150F that has a pretty bad wobble in the front wheel.  It has the OEM rim on it, 19x1.40 w/36 spokes.  For some reason, Honda is REALLY proud of their CRF150F rims, and want $125 for a new one.  However, the same size front rim from an XR/CRF100 or CRF125F are only $25-$30.  I realize that the spoke/nipple sizes are different, but is there any reason I couldn't use an XR100 rim and lace it with CRF150F spokes if I drilled the holes out larger?  Could nipple size be an issue?  Center well depth?
      I'm not looking for weight savings, or bling, just a straight wheel assembly.
      Or, if nobody knows the drop-in capability, I sure could use a lesson in spoked wheel compatability.  Does anyone know a good site for learning what features really matter when trying to swap rims?
      Thanks for the insight in advance.
    • By ccasey75
      Looking for BBR upgrades for 2006 CRF230F including the following:
      Heavy fork springs
      Heavy shock spring
      BBR Triple Clamp
      BBR Linkage
      Shock upgrade
      Let me know if what you have and how much you want!!
    • By Christo6060
      They will fit with some modification I did it on my bike 2007. The 2015 through 17 has an extra mounting hole on the tank and shroud so I cut the threads off an extra mounting screw and superglued it in that hole giving it a more authentic look. Except I didn’t use enough glue on the right side and the screw fell out. I had to use spacers on the front mount. And drill a new hole on the original tank mount but that doesn’t effect the original shrouds mounting. And a new hole on the new shroud. The new shrouds also sat correctly against the tank not affecting the seats look. Pictured is the two shrouds next to each other and the bike with the original shrouds. Also pictured is the listing for the shrouds and I only  spent $30 AUD on the OEM shrouds which were listed at $35 after my offer was accepted. They came with new hardware. And it was well worth it. I hope this post was worth the time😂.
    • By Fisforfun
      SOLVED*** No timing issue, just had trouble lining up TDC  Going to rebuild top end to fix low compression. Thanks for the help TT
      So I bought my 2003 crf230f a few months ago from a friend. The bike has definitely been ridden, and was blowing a little bit of smoke when I bought it so I knew the rings would be toast sooner or later. After a basic tune-up the bike ran really strong and I continued to ride it a few times a week for a couple months with no problems... Until last week when I was riding and it died on me. At the moment when the bike died, I was coasting down a hill so there was no extra stress on the engine, I just noticed the engine shut off- almost like running out of gas.
      From that moment on, the bike would not start so I towed it home and checked the essentials... Air, Fuel, Spark, Compression.
      Air- The new air filter I installed when I bought the bike was already covered in dust, so its possible the piston rings got even more dusted. I cleaned and oiled the filter anyway (the bike wouldn't start with the filter removed).
      Fuel- I recently changed my jetting to Mike Coe specs, and installed a larger pilot jet to eliminate popping on deceleration. The bike ran great with the new jetting and I know the carb is clean. I went ahead and cleaned out the gas tank and fuel lines and cleaned out the carb yet again.
      Spark- Spark plug was white due to running lean before I changed the jetting. Plug turned more of a brown color after jetting, indicating better A/F ratio. Replaced spark plug anyway and can see strong blue spark. Also, gas is making it to the plug.
      Finally did a compression test and had low compression. I adjusted the valves which were a bit out of spec, and saw no improvement. A wet compression test (one tsp oil in plug hole) showed higher compression, but still low, indicating the piston rings are toast. I ordered new rings and top end gaskets and will rebuild the top end next week.
      I was also wondering if I have a timing issue, since the engine at TDC (pic 1) shows the cam sprocket about 30 degrees (in the retarded position?) off from being horizontal with the head, as it should be according to the FSM and Clymer manuals. Also, when cranking the engine CCW by hand, the flywheel tends to spin past TDC and happens to align the cam sprocket perfectly horizontal with the head. Is my timing way off? Also, the flywheel has a || mark (pic 2) near TDC that I used to adjust the valves. Just today when I took the pictures, I noticed a |F mark (pic 4) that usually spins past quickly so I never saw it before. both marks appear close to TDC but the engine always wants to spin to the natural position (pic 5). Where is my true TDC? Manuals only show a |T mark. Are the cam sprocket lines supposed to be horizontal with the head? Maybe it jumped a tooth? I have read the cam chain tensioners are known to fail also.
      Edit: Found the T mark, updated photo near bottom of thread
      tl;dr
      Bike died on me, has low compression, going to rebuild top end. See pictures. Could this be a timing issue also? Does anyone know if the lines on the camshaft sprocket are supposed to line up with the horizontal lines on the head? Thanks in advance for the help!
      Pic 1- TDC at || https://imgur.com/QJXXjXH
      Pic 2- || mark https://imgur.com/v7dBSf8
      Pic 3- TDC at |F https://imgur.com/DZCPBaT
      Pic 4- |F mark https://imgur.com/JbcVYhF
      Pic 5- Engine wants to spin to this position: Cam sprocket lines horizontal with head- https://imgur.com/S3rPRgd
      Let me know what you guys think. Has my timing jumped? I appreciate your help!
      Cheers,
      Spencer
      Edit: Finally found the damn "T" mark. Always spins past so I wasn't able to see it before. Updated picture posted near bottom of thread. Timing looks fine so  just going to rebuild top end next week to restore compression
