Coolant out the weep hole, bike froze?
I winterized the bike correctly and put in 50/50 coolant/water but when I went outside to put my forks back on the bike I noticed a smal amount of coolant on the stand under the weep hole...:applause:
Could the bike have frozen? Just the water pump Froze?
What will I most likely need to replace?
Bike is an 06 250X with only about 30 hrs on it. I started it up to see if it ran and it ran well. I checked the oil and it is still perfect (I changed it before storage), not milky at all.
anyone?
I would guess that if it did freeze once it warmed up you would have a lot more coolant on the floor than a small amount. If you ran the bike and there is not coolant coming out you should be ok. Just keep an eye on it. You could have over filled the rads when you winterized it.
The rubber seals got cold and weeped, hose clamps will do the same thing. You could try a different antifreeze with distilled water. If it keeps leaking need to change the seal. You can't over fill the radiators because any excess coolant would be pushed to the over flow tank.
I ALWAYS use distilled water and I used a long-life coolant. I only used long-life becuase I that's what I had. Every Spring/Fall its changed for Engine Ice or equivalent.
When I started the bike up, more weeped out but it was not excessive.
Is your coolant full now? I would drain the system and re fill it with what ever you are going to run this year and see if it holds coolant. Warm it up and see what happens. Check to see if you have water in your oil. I would guess that if you froze anything and it broke you would have no coolant.
oil is a pretty amber :applause: Luckily it seems like the head is A-OK!
I will check the coolant levels tonight.
oil is a pretty amber :banghead: Luckily it seems like the head is A-OK!
not sure if this applies, but, thre weeks or so ago my friends and i went riding when it was very cold. two out of the five bikes, both a couple years old leaked at the water pump when they first cranked. they stopped leaking after 30 sec to a min. the only thing we could figure was that the seals were cold therefore hard. when they warmed a little they began to function again. if you don't have water in the oil or water still leaking, i would not worry too much, just keep an eye on it for a while.:applause::):cry:
Just a guess but plastic or rubber will shrink faster than metal in cold conditions. Therefore a small amount of coolant could have gotten by the seals causing the weep. With a 50-50 mix it would have to be very cold to cause damage. I would keep an eye on the levels(oil & coolant) but i doubt you have anything to worry about. If you want a real piece of mind change your coolant to Evans. It is completely waterless which helps with cooling and it never freezes. Awesome stuff but expensive. Good luck!
yeah i saw this on mine too. nuthin to lose sleep on
Happened to you to?
yeah...we went from the negative numers for a few days to the 40's. i noticed a tiny puddle on the floor. i only see it when there is a big temp change
I bought all the parts just in case, but if what you're saying is true I shouldn't have to worry. I'll keep an eye on her for my first few rides and see what happens.
Thanks for all the help!
No and no. 50/50 freezes at -40F. Unless you were putzing around when it was -40F (thats just about when spit freezes before it hits the ground) then you didn't freeze anything. I suppose it is possible that the waterpump seal might leak when cold -- seems unlikely, but you never know.
JayC
  • Similar Content
    • By bob_slinger
      I enjoy riding flowing single track and double track with some small technical sections, nothing insane. I'm also way too cheap to spend thousands of $$$ every riding season on maintenance and rebuilds. I've owned a dual sport 1987 XL185 that was underpowered but predictable and a 1991 YZ125 that was overpowering and exhausting in technical stuff (though I'm not a fan of 2-stroke exhaust and noise).
      I'm 6'1" and 200 lbs with riding gear.
      I've narrowed down my choices to Honda CRF250L (heavy and underpowered but low maintenance), Honda CRF250X (smooth power but expensive maintenance), Husky TE250 (smooth power and easier maintenance than CRF250X), Husky WR125 (super light weight and easy maintenance but 2-stroke) and KDX200 (cheap, lightweight but 2-stroke).
      I realize that the CRF250L is more road oriented and closer to my vintage XL185 - I'm considering putting on more aggressive tires and raising the bars. I like that the CRF250L engine has a 8,000km service interval though it is greatly underpowered. I don't mind trailering a bike, so road worthiness is not a deal breaker. I'm concerned the CRF250L will be cramped for my 6'1" size and I've read that the rear suspension is too soft and sags significantly for anyone over 180 lbs.
      The CRF250X seems like the best choice for single track and woods riding but I've read that rebuilds can be expensive and complicated. I've ridden the CRF250X a few times and it feels slightly bogged down at lower rpm.
      The TE250 frame and design look easier for rebuild/maintenance and people have said it is more agile (I've raced mountain bikes most of my life so I appreciate a maneuverable bike).
      I'm only considering the 2-stroke WR125 and KDX200 because they are super lightweight and should have a smoother power delivery and better low-end grunt than my old YZ125 on the trails. I'm not a fan of the sound or smell of 2-strokes but if it makes the riding experience that much better I would consider a 2-stroke.
      Hoping to get some feedback before the spring riding season.
    • By JacksonDRZbeast
      I am currently in the thought process of purchasing a crf250x and converting to supermoto to get it registered for road use. Just wondering if anyone has converted and what tips you would have for me to maybe make it easier? I already have a set of SM wheels off my drz that will fit with new spacers.
      Any advice will help!
    • By GregWB
      Has anyone fitted grease nipples to the rear suspension component and swing arm to CRF250X? Compared with my old XR350R, is ain’t a step backwards not being able to grease the CRF.
    • By Kaito Sutton
      So I’ve got a 09 crf250x and from every angle I’ve been shouted that the airbox mod will be the best thing in world along with a jd jetting kit. At this time I’ll being using the stock exhaust, so I’m wondering if doing these mods will void the registerablilty of the bike. I’m in nsw Australia. Also, anyone with experience with this mod, does it make it louder? As that is the main issue with getting is registered. I’m planning on doing the mod this afternoon so if someone could let me know ASAP that’d be awesome  cheers
    • By MNThumper250
      I'm tearing down my '06 CRF250X for winter prep. I checked the spark plug (see pics).
      I've rode with this plug for most of the summer. I'm thinking it's a bit rich, so for the other 250X owners out there, what jetting are you running/what do you think I should run? The only mods I've done is install the JD Jet Kit (165 main, 42 pilot, Red needle 4th clip, and thick o-ring), FMF Q4, and 4" x 4" hole in air box (with No Toil Super Flo Kit). The bike seems to run alright, but should I drop a few on the main jet?
