450x and 450r air filter
does the 450x 06 have the same air filter as the 450R i want to buy a k&n for my bike but they have it for the 450R only please let me know:confused: :applause:
Oem filter for 450 R & X are different, but usable on a 450X
That's the first thing I thought about after getting my 450X... well ok, maybe the second thing actually, getting the K&N Air Filter. Having used K&N filters on all my vehicles, I was not too thrilled about the thought of cleaning the old foam filter. I went to the K&N site and like they suggested, requested the filter be produced for the 450X. Wonder if they really do respond to those requests? Guess we'll see.
And... I can't produce hard evidence but I'd say each of my vehicles [bikes, car and truck] all perform just a little better with that K&N filter installed.
You may find, if you do some searches, that the overall feeling about using the K&N filter on the X is that it is not a good idea. The K&N does let in more dirt than a foam filter, which is a very bad thing for titanium valves, and a precision motor in general.
I have tried K&N on previous motorcycles, and have discovered a very fine layer of dust lining the intake boot. Not good.
+1 ^
K&N is ok for the street but in a really dusty environment like the dirt the K&N is really hard to clean and keep clean.
  • Similar Content
    • By TheVolta
      New bike is confirmed, your welcome.
    • By DanielX450
      Hey guys I could really use some help. I bought a 2005 CRF 450x that has an aftermarket air filter, full FMF exhaust system (pipe and header), removed backfire screen, and removed air snorkel. Bike idles and starts just fine, but when I hold the throttle anywhere from barely at all to about 1/2 it bogs, wants to die, and backfires. Seems like lean running conditions to me because if i leave the choke on the problem mostly goes away. Additionally, if i move the air screw out almost all the way (to the point where it could vibrate off), it seems to clean up a little bit. I am trying to determine whether bigger jet(s) would fix it or if its something else. My dad thought it might be the float level, but I'm really not sure. Thanks in advance for your help!
    • By pro dirt
      hi, I'm buying a crf450x and this is the first 450x I'm gonna own but i was a bit confused on one of the pictures. i checked on other crf450x pictures and could not find this on any of the others. There is a gap right below the air filter and above the swingarm and I was wondering if it was normal.
      Thanks!!!
    • By David Rediger
      I have a 05 CRF450X that was just rebuilt that is not starting via its electric start. I can start it with the kick starter as well as a rolling start down a hill though. Once started it seems to run just fine. I have it at a bike shop right now and they are stumped as well. So far I know the battery has been tested/replaced, the carb has been cleaned, jetting is good, and they have also tested the starter motor and things all look okay. Any ideas where to look next?
