KX 65 question
I'm seriously considering this bike for my nine year old. He's kinda on the small side at 4'2" 54lbs. Any thoughts. Also for you CA guys...any knowledge if a year group was green sticker?
Most of the riding will be trail and desert. Will start taking to the track as soon as he gets used to it.
That really depends on what machine your son has prior experience on and what his skill level is.
Some might disagree, but the KX65 is very aggressive and the powerband comes on really strong. I've seen quite a few parents step-up to the 65 and end up selling it for a KLX110 or likewise machine because it was simply too much for their kiddo.
If you son is upgrading from a 50sx or something similar, I'd say have at it. If you settle on the 65 and find that it's too much for him, you can always detune the engines performance until he's capable of managing the power.
He's been riding a TTR-90 around for the last year. A CRF50 since he was 6. He shifts throught 90's gears pretty well. I thought about the TTR110 but it would just be very similar to the 90. I need to give the 90 to my 7 year old that is totally beyond the 50 now.
My 9 year old is a prettly solid rider with good throttle control and common sense.
After a TTR-90, I'd say he's definitely ready for a 65.
My son stepped up to a KX65 at age 10 from a KLX110. Getting used to the clutch and the power band was an adjustment, but didn't take him long. He loves the better suspension, more power and lighter weight. Double check me on this but I believe '02 and older are green sticker.
I moved my son from a KTM Pro Jr to a RM65 (exact same bike as a KX65) at age 7. Now he's 9, 60#, and about 48" tall. So from a size perspective, I'd say your son should be just fine.
I swapped out the stock fork springs for ones that were 2 steps softer from Suzuki (tip: Suzuki parts are often cheaper than Kawi ones), raised the forks until they just touched the bars, and spun the shock preload all the way up.
While it is an aggressive motor, it's nothing that can't be learned or overcome. We've been on MX tracks, desert riding, trail riding, and yesterday came home from Pismo sand dunes. Great little bike.
2002 and older get green stickers, 03 and newer get the communist sticker. 00 and 01 bikes had smaller frames, forks, and some other minor changes. Sounds like you should be looking for an 02.
My son started riding last spring at age 7, spent one day on a CRF50, then onto a CRF70 for a few weeks, then bought himself the KX65 mid summer, he was in the power band immediately, just loving it, and was jumping it the second day he owned it. They're a handful, but if your son has a good head on his shoulders, he'll be fine with it.
Thanks for the respones guys. I really appreciate it. It's hard to get any help on the TTR forum. I am looking at an '02 now.
Since you're in CA, I'd highly suggest Craigslist, the Recycler and Cycle Trader. You should be able to find an '02 for $9-$1,200 or so.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
