how to bullet proof head\valve for high rpms..
85 hours on my '07 crf450 and shes hard to start. valves have started to move and i see no point in shimming. it just delays the inevitable.
i rebuilt my '05 right before trading it in on my current bike, and i went back all oem because i wasnt going to own it much longer. that may not be the case with this one.
straight to the point, i am a revver. i ride my bike high in the rpms, always have, its just my riding style. what can i do to my valve train to make it more reliable for turning high rpms? ss valves? different springs?
my plan is to buy an oem head (i can get them cheaper new, then to fix my old) and then lap whatever valves i get myself. also replacing piston\rings, etc and will have the cylinder honed (assuming it is within spec)
im looking for solid professional advice only please, thanks.
I mostly ride at the dunes so I ride at high rpm's for extended periods of time. On both my 03 and 05 I went with kibblewhite springs and valves, my 03 was put through the ringer and I never had to adjust the valves after installing kibblewhite. The springs are stiff and valves are a little heavier but for longevity I dont think you can beat them.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
