New Piston and valve work, timing chain too?
I'm getting at least new intakes, and I'm installing a new OEM piston kit. Should I replace the timing chain? If so, where is the best place to buy OEM?
Thanks,
Steve
Thanks,
Steve
I would think about getting a high comp piston while I was doing the top end. It is a good mod and not that much more money.
Yes, replace the timing chain and the cam chain tentioner (CCT). I went manual CCT and I check the CCT adjustment every valve check.
Good advice! My tensioner had the spring/metal winding work it's way out of the housing. Luckily it got caught on the gasket sealing surface so I caught it before runing the motor. I would also check the plastic sliders as well. One of mine was cracked.
