Decking head same as Clay mod?
Does anyone know if decking the head is the same or similar to Clay's head mod? Thanks
Clay's head mod is situation specific. - for your riding syle, gas used and problem to overcome.
I think the deck shave you refer to probably means milling off the mating surface to increase squish and compression. However I am unfamiliar with this term being used for a head (usually refers to lowering a cylinder). No matter.
Bottom line is you have to call. Another option is www.jbonemotorworks.com
Joshua from jbone knows KTM's and will take time to discuss.
Anybody know if Clay still works at Munn? I see the www.cmmachine.com isn't a working site any longer.
I can still get to it!On it right now
You're right! I hadn't checked it for a while - must have been down for maintenance / upgrade when I checked.
