ONLY 1,675 miles (1977 DT100) Engine Problems - Help!
1977 DT100 With Only 1,675 miles
I just purchased a used 1977 Yamaha DT 100. The motorcycle was purchased from the original owner with only 1,675 miles on it. When I got the bike it would start only for 3-10 seconds, then it would putter out. I figured that It would be a quick fix and that I only needed a carb rebuild. I rebuilt the carb, and it fired right up and idled very nicley.
I rode it around for about 9-10 miles and the engine seemed like it had little or now power on it (it would rev real high but wouldn't pull very quickly) I realized now that there may have been a previous engine sieze. So while riding it on my way back to my house while going up a slight hill the engine had a loss of power and stopped. Then I couldn't kick it over again.
EXIAMINATION:
I Took out the engine and removed the cylinder head and the top of the piston looked like it had been beated up (not a good sign) and the underside of the head cover had some metal pieces which were hammered into it. I looked further near the bottom of the rod (where it connects to the crankshaft) and I noticed 3 small pieces of metal. They are about the size of a piece of rice. I removed the piston to check the piston bearing and the bearing pins were all in good shape. I'm assuming (???)that the bottom end rod bearing may have failed releasing the pins of the bearing near the crank, and somehow they got up the cylinder on top of the piston, causing it to sieze? I havent taken apart the case yet, to determine if this is the actual problem, but I dont know if it's worth my time to determine the problem.
QUESTIONS:
Should I bother rebuilding this engine or just get a used engine? Do you think that if the bottom-end of the rod bearing failed and the bearing pins came out that it would have damaged other areas of the engine?
I'm bummed out, especially with a bike with only 1,675 miles on it. I cannot believe the lower rod bearing failed - I have never heard of this happening? Any ideas on labor costs to split the case and replace the parts and re-boring the cylinder wall?
does anybody have any recommendations on where I can get a used DT100 1977 engine? any ideas on prices?
Thanks!!!!!!!!!!!! & Happy Riding
Sounds like the lower end bearing had gotten a little rusty from sitting and all it took was too fire it up to kill it.I'd put a rod kit in it.Sounds like it could be a real nice little "trail bike for the kids".The old simple stuff really hold their value.
I would think the odds of finding a better engine than the one you have to be impossible. They are getting up there in years. It would suck to buy somethign else you needed to rebuild.
Do you know where i can get a new Rod Kit for this bike?
hay there is tons of engines on ebay going for cheap im in the processes of rebuilding a 74 dt175. so i have looked at almost every add on ebay for that bike. there is most likely 3-4 engines on ebay right now. mabie not for a 100 but i am pretty sure you can put a 125-175 in there to.
  • Similar Content
    • By faizakhtar125
      Hey guys I read an article saying that the 01 YZ125 has six gears. But other people are saying that it's 5. How many gears does it have? Just asking. Thanks.
    • By idratherberiding
      2006 YZ 250.. The manual calls for 10w30 (yamalube 4 stroke oil), can I use 10w50 (Motul semi sythetic 4 stroke oil) ??   I bought the bike, want to change the gear oil before I ride tomorrow but all I have at the moment is the Motul 10w50  semi synth.  Is that oil going to be too thick compared to the 10w30 or will it be fine..  Thanks
    • By faizakhtar125
      Hey guys I just wanted to show off my bike and show it to the world lol  What is your opinion on it. God or bad, please be honest. I am open to all comments and suggestions. Any upgrades I should do to make it look better and/or faster?
    • By Allooushh
      I bought a YZ250F yesterday and the previous owner said apparently it runs but they weren’t strong enough to kick it. I couldn’t kick while there so I took their word for it and bought it. I’ve been trying to get it to fire all day today, there are 2 chokes and I’m unsure if the air mixture is correct, so would be nice to know what I should do, it’s hard to adjust the air screw when the bike won’t even run. I noticed the spark is kinda low, I don’t know if it’s normally supposed to be like that or not. I can see a blue spark but it is very small and crappy, I’ve had thumpstars that generated stronger spark, I changed the plug it’s still the same, so maybe could be an electrical problem, the only ground connection I could find was for the ignition lead which I filed down to bare metal so I’m pretty sure that connection is good. Anything else I’m missing? It’s very hard to kick and I can feel the compression out of the exhaust so I don’t think compression is the issue.Just wanna know what I should do, haven’t owned a yz before so I could be not using the choke right or something. Thanks
