Stock '07 yz250f bar size?
If you're talking about the full bark busters then you'll need the 1 1/8" adapters/clamps for the inner part of the bar, you should be able to use the metal bar/guard though. If you have just the plastic hand guards then they might fit on the 1 1/8" inch bar - that is if they only attach near the grips because that part is 7/8" in diameter.
Well, its the moose aluminum, they look like they might work but im not sure..
Its these http://shop.thumpertalk.com/catalogs/Parts_Unlimited_Offroad_2007/default.asp?p=591
