Mukini Jetting Help?
Have a 2005 Suzuki DRZ-SM
3x3, JD Jetting Kit, Kientech
adding a full Muzzy Stainless Exhaust
At Sea level most riding
What needle setting, jets, Turns on screw, Etc
Thanx in advance
Did you read the instructions James Dean did? He spent a lot of time making them up.
Fuel screw settings in the 'book' are recommended starting points. Every bike is different, as is the temp and altitude. Set the screw according to this method.
Gently turn the screw all the way in. Now back it out two turns. Start the bike and fully warm it up, go for a 10 minute ride. Set the idle to speed to 1,500~1,800 RPM as best you can (I know, without a tach this is tough, just set it to were it idles relatively smoothly). Once warmed, slow the idle to the lowest possible speed.
*** When turning the fuel screw, keep an accurate 'count' of the amount you are turning it and record it in case you have to reset it for some reason. Makes life easier when you can just set it from notes Vs. going through the procedure again.***
Turn the screw in until the idle becomes rough or the bike stalls.
if it stalled, open the screw about 1/4 more turn. Restart it and slowly screw it in till you can just perceive a change.
If the screw can be turned all the way in and the bike still idles perfectly and does not stall, then you need to go down a size in pilot jet.
Now very slowly, open the fuel screw till the idle is smooth. Blip the throttle, let the bike return to an idle, wait say ten seconds. Confirm it is the same smooth idle.
If the screw has to be opened more than 3 turns to get a smooth idle, you need to go up a size in pilot jet.
If you find it does not stall with the larger jet but has to be open more than three turns with the smaller pilot jet, put the larger one in and set the fuel screw at 1/2 turn.
If the idle speed increased, adjust the idle speed knob to return the bike to a real slow idle speed. You must then re-visit the fuel screw. Keep doing this till the fuel screw is opened just enough to provide a nice steady idle at the lowest possible RPM. Once this is done, increase the idle speed to the normal one for your bike, typically about 1,500 rpm, but go by the spec in your manual.
Be sure to keep notes of your settings. You may find you need to make a change, say if you're riding in the mountains or down at the beach. Returning home, it is a simple matter of referring to your notes to restore things.
  • Similar Content
    • By whiteduke13
      Bought a 1999 Yamaha xt350 couple months ago from a guy that hadn't started it since 2011. I started off removing majority of the big chucks of rust from the tank via bolts/vinegar, and replaced the fuel line, and inline filter with a see through material. Additionally I had the carburetor cleaned by a local shop. The shop messed something up and now the choke is stuck in the closed position, but the bike ran fine for two days in a row (about 2 hours each day). A week later it started dying while riding and I believe its because fuel isn't making it to the carb. I've checked the screens on the petcock, and replaced the tubing and filter to the carb. Before having the carb cleaned the inline filter would completely fill up before starting the bike but now only fills to a third of the way. The inline filter goes dry when running thus the motion fuel isn't making it to the carb. Flow through the fuel line is at a trickle when connected to carb but gushes when fed to a gas can. Any ideas to why I'm not getting flow???
    • By Kawasuzuki456
      So I have an 03 rm 125 and I’m having a problem with my jetting. My original 460 main jet that came out of the carb is huge and unlike any jet I’ve seen before. I also ordered a mikuni genuine main jet off of eBay and went to go put it in the carb (440 main) and it’s way too small. Not sure what to do.
    • By AKrazy
      Hello kids,
      Looking to get my second dual sport. Ive been riding for 3 years on my DR200. I mostly prefer single track and technical riding.
      I recently test rode the DRZ on dirt. I liked the extra grunt, but found it too tall for my legs and too top heavy for my riding style.
      Anyway, I like what I've read about the KLX250's suspension and aftermarket mods. I see "easy install" kits and directions all over, but no information as to how the 2018 kid's EFI will change installing these kits.
      Will it require an aftermarket EFI? Or possibly even a carb swap kit?
