Rear brake Rotor Size SM and S ???
What is the diameter of the stock rear brake rotor on a SM ?
And for the S ?
Thanks, Jas :applause:
An S is 230 mm, an RM 240 mm. An SM no idea.
Save yourself some bucks and buy some S take offs I got mine for $20 each.
S rear is 220mm (not 230mm), SM rear is 240 mm.
You can buy the RM bracket for the S to accept the SM's 240mm (while retaining the same caliper).
That's what I did and I like it better than the stock S size rotor. It will let me use the RM rear wave rotor with my SM wheelset.
Yup (:smirk: ) opened the box up and so it is. I'll have to correct my notes. I have been running an RM bracket and rotor for a couple years now. First time I've looked at the rotor since.......
So is the concensus now, you can either buy a DRZ SM rotor or an RM125/250 240mm rotor from 2001 and up for my rear dirt wheel and utilize a RM carrier, so I have an easier swap from street to dirt and visa versa?
Please let me know as I should be done with the hooligan mod by this weekend. (I actually bought the wheels that Jonala had machined already, I just need to figure out the spacer stack up and install. My son was crying when I picked up the wheels, so I didn't have a lot of time to ask questions about the spacer stack up):banana:
By the way thanks to Plane Dr, Nate, Russ, Jonala (you did most of the work for me as I brought them primarily complete) and others for the motivation and informative information. :)
When I am finished I plan to take some additional detailed pictures when done to help others.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
