Tire / Rim Fitment
Anyone think a 150 will be too narrow for a 4.5 inch rim? I don't see a problem just a query?
(Please don't mention oil)
It sounds like it will work. What tire are you thinking of putting on the back?
it will be fine.
Thanks Eddie. :)
I figured it would be, just checking..... I am used to old stuff with skinny tires....
I am going to a pilot road 2 rear. With a pilot power front. I want to slow the handling down a bit.
The last one was a 3.5 with a 150 and it had some "tip" in.
2 bikes 3 sets of tires the soft stuff thins the wallet too much.:applause:
How about a 150 on a 5" rim?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
