Race Gas in the X
Lately I have been reading about the advantages race gas is over pump gas. Not oxgenated, burn cooler, better throttle response, etc. So I am curious what you all thought? Or if any of you use it and what kind.
I use 110....the purple stuff.
Everything I have read, if you have a stock motor, you are wasting money.
Now if you start messing with Duration and/or higher compression now you may have some benefits.
I also feel it's not necessary on a stock bike. And think of your buddies... ever ride behind a bike running race fuel?
I love the smell of race gas and I also love the smell of 2-stroke exhaust but I'm insane. I like leaded race gas because valves last longer and it burns crisper and cleaner. Probably not necessary with stock compression performance wise though.
Don't you need to have high compression pistons etc. to run race fuel?
i ran half and half race gas 91 in my bike for a while. I didnt notice anything too great while running it. Besides the smell of course. But unless you have an aftermarket piston kit with high compression then you cant run full race gas. It is expensive.
stick to the highest pump gas 93,91,95 if you can find it.
If you can afford it I would run it. By raising the octane level in your fuel, you lower the running temp of your motor. You won't gain any horsepower overall to speak of but you will notice a difference. My brother ran short on fuel over Thanksgiving and used my 100 Octane pump gas and noticed better throttle response and better mileage also. Maybe he's not having to strain the motor as much I don't know, but he hasn't made a trip since without the 100 octane.
Blenzall, race gas, and apple pie. How could you not love the smell?
Waste of money, even on a mildly modded bike (pipe, air box, cam, big bore kit). Only time I ever used race gas was in in my land speed bike (built for unadulterated insane HP). It was built to take advantage of it. Didn't even use it when I raced in CCS/CMRA road racing. Race gas itself doesn't store more potential energy. You need the mods.
... there are lots of fact, and lots of fiction... mixed in with personal ideas of what should be blended and not.
Do a search... there's been so much discussed on this, it'll turn you blue. In fact, I posted a bunch of "fact" on this a while back... and some arguements insued.
The moral of the story;
When I run my bike hard (racing, dunes...etc) I run it 50/50.
More or less peace of mind, but coming from a 2stroke world of thinking.
You need to understand it changes the bike. Mainly the jetting. And yes, it helps the bike run a bit cooler and less chance of detonation. But it does nearly nothing for performance enhancement. If you want that... try Bob's remedy; Enzyte. :cry: (speaking for stock compression)
If you want it to smell good... use alcohol additives like "fuel-fragrance"... it's hilarious when a bike rolls by smelling like pina colada. :)
Bikes that are excessively lean seem to benifit from race gas, for obvious reasons: they now can operate at a lower tempeture, so you experience less power loss. I think that's why you hear so many 'my bike is faster on race gas' when it's probably just stock, and not properly tuned. I do notice a bit of throttle reponse improvement on my R and X, but it doesn't go any faster. You are not 'gaining' power. It's like liquid jetting. Did I just say that? Gnarly.
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
