Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
TRX250R - Doesn't have any top end
I will post this here, hoping maybe someone out there has run into a similar problem.
The engine pulls pretty strong in a very narrow rpm range (mid range), but will not rev out cleanly. Due to other mechanical issues, it has a complete new engine (including carb, stator, reed cage, etc) but this problem has remained. The only pieces remaining are the FMF pipe/silencer and the ignition coil/wire/ignition box. Before I spend more money chasing this demon, has anyone else out there experienced this with a 250R?
Thanks guys!
well what size carb did you put on it?? I was runnin a 38mm airstrker on mine when it was stock, and it wouldnt pull at all, but once I got an esr trx 5 and a k&N filter and some other stuff it ran fine, you may want to think about selling that fmf and looking into the esr trx 5 pipe, it is the best all around pipe for the 250r
As above you need to give more detail. What size carb, what main jet? I run a 37 smooth bore on mine but I also have a ProX 310 kit. If you have the airbox lid on the bike can't breathe very well. That would be the first thing I'd check. Run it with the lid on then run it with the lid off. See if it gets better or worse. Will help you fiqure out which way to go on your main jet at least. Sounds like it may be real rich.
It used to have a larger than stock carb on it, though not sure what it was. When it was on there, I tried going back and forth over a pretty wide range on the jetting, to no avail. I picked up a used, bone stock carburetor for it, and started with slightly richer than stock jetting (it has the FMF and a K&N cone filter), but the problem is almost identical as before (first ride was yesterday). It does feel stronger in the very very narrow midrange, but the end result is still the same. Plug is always resonably clean, depending on how far I jack the jetting around.
Thanks for the replies guys!
Are you running the stock cylinder without any kind of porting modifications? If so, I think you might be limiting yourself. The FMF pipe is kind of a cheaper pipe in my opinion. It doesn't match the stock porting very well and seems to fall flat on its face when revved higher. That pipe does seem to work well with longer exhaust durations though, and it revs out surprisingly well. If you don't want to start cutting your barrel, I suggest trying the ESR pipe. It has less tapered cones and matches the stock porting better.
That could be it, I am out of ideas. The engine is bone stock. The problem has existed on 2 engines now, with different carbs/reeds/stators/etc. The only carryover parts have been the pipe/silencer and ignition system. I just have not had time or money to swap them out.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
