help with 94cr125
alright i have a 94 cr125 fresh top end (5 hours)
fmf fatty.
reed spacer.
twin air filter.
elevation 94 feet
temperature 80
what would be a good place to start?
ok the bike wont idle correctly.
and is currently running lean.
with a bad bog off the line almost stalling
This is just my experiance so take it with a grain of salt
Ive found on my bike(92 cr125)
The PJ carb is hard to get a constant idle best just to set it on the day
I was fouling plugs like mad with:
55 pilot
170main
2 turns on air
middle(3rd)position on needle
Spoodge everywhere
Am currently running
50 pilot
170main
2.5 on air
2nd position on needle
seems ok but havent really tested it fully
I normaly ride trails so its not the best bike for the job gut like to think it is capabe of it............Other than that with a few rides on my personal track it seems to be responsive enough and the plug is new so with only bout 40mins on it its showing a little bit of darkness but its dry at least and less spoodge
And I also did the clutch side main seal at the same time as the jetting changes........Good Luck and if you do find a good jetting setup PLEASE ledt me know
