Just put my bike on a Dyno machine
So my buisness that i work for just got a Brand new Dyno Machine.
Were still working on getting it dialed in.
So i threw my 08 YZ250F on it.
Initials test: 23.5hp at 6700rpm.
Has anyone else tested their 250fs on a Dyno?
Does anyone out there know if this is pretty acurate?
totally 100% inaccurate. I imagine you were running a knobbie?
you need to run a slick tire to get accurate results.
The peak should be between 10k and 11k rpm. Yes, use a slick/street tire if you have one.
ill get the name and make and year of the Dyno maching monday.
So does anybody know what the peak HP is at what RPMs
run it up to 12k before you back it off and you garunteed to get max hp. it hits limiter at 13,500 but the hp starts to drop around 12,000.
Doesn't hp specs change engine vs rear wheel?
Rear wheel hp might be far less than engine hp?
What is factory spec, engine or rear wheel ?
dwilkinson
If the crank HP is ~31, 23.5 is a ~24% power loss, that seems pretty high for a lightweight dirtbike drivetrain.
not if you stick a pole in the spokes :thumbsup:
The brand of dyno is important here, they all read differently.
Are you step testing or inertia sweep testing?
Something is strange with peak HP being produced at 6700 for sure.
Remember dyno's are tools. Used accurately before and after to measure percentage of change is optimum. One peak number from dyno "A" RARELY matches the peak number from dyno "B".
my bike makes its peak power at 10K, going up olds hill in 3rd pinned, it went up to 11k, got knocked down to 9k and evened the rest of the way at 10k
who needs dyno's, I HAVE HILLS, haha
33hp stock is what i believe the YZ is rated at, and most places like rick peterson motor sports and other places like that show that being the baseline.
but for some reason, my bike won't hit over 12870 on my tachometer before the rev limiter kicks in, ***. I can hit 86mph stock and 93 with my 13/48 final drive.
To know when to shift. you lose hp in the over rev. I can get 5mph more in a given distance behind my house shifting at 11k instead of the rev limiter.
it also has shift lights. tells me my engine coolant temp.
and its cool.
I have some videos of it on my myspace. myspace.com/jordanleyva add me if you please
Ha, ha. No, I wasn't asking what you have a tach for, I was just wondering what you are using.
