450x Help I Want To Ride Tomorrow>>>
Just got the bike back from the shop where they re-jetted the carb. Now it is hard to start and once it starts it shuts off as soon as the choke is pushed back in. It is running rough and backfiring too. Help I want to ride tomorrow
Ummmm.....Didn't the shop check it out to see if it ran right before they gave it back to you? That's messed-up!! I don't know where to begin to help you out here other than maybe looking for a rag in the intake boot and maybe trying to adjust your fuel screw. Rag in the intake boot is probably it....No kidding.
Yeah if its not a really dumb mistake (such as a rag in the boot) and they gave you your bike back like that after they "rejetted" it, then that is messed up. Make sure that the carb is fully seated in and you don't have any air leaks as well.
Started up when I got it home, but that was about two weeks ago, now it is fighting me left and right.. Any other ideas?
Pull the float drain and clean out the jets with a paperclip maybe. Might be gunked up from not having any gas run through it in 2 weeks.
sure sounds like a plugged pilot jet. Do you have the jetting specs that they put in? They might have put the wrong size in. I would open the fuel screw a turn and see if it gets better. What part of Ca. do you live in? I have a few pilot jets in the garage.
AAAH! Don't use a paper clip please! One strand of wire from 18ga speaker wire is plenty.
HAHAHAHAH! A small paperclip then.:thumbsup::ride::eek::D
sure sounds like a plugged pilot jet. Do you have the jetting specs that they put in? They might have put the wrong size in. I would open the fuel screw a turn and see if it gets better. What part of Ca. do you live in? I have a few pilot gets in the garage.
:thumbsup:
Might be as simple as turning the idle up a tad!
Compressed air and brakeclean works well for cleaning the jets. If you have the jet removed make sure you hold on to it or it will end up on the other side of the garage floor! Been there!
...and hold it up to the sunlight, to make sure it is clean clear through.
may sound dumb but check your fuel level.try starting it in reserve
Thanks for the help guys, it was my neighbor and his wife called him home. But I will forward the suggestions, I think you are right about eat being a jetting issue, bad gas or something, when it did run it kept reving on its own...
Air leak somewhere?
Air leak somewhere?
Thats what I'm thinking. Make sure the air filter is on all the way (right way). Check around the carb to make sure its fully seated and tight. Try spraying carb cleaner or WD-40 around that area to reveal any air intake leaks (while bike is running). If there is one the idle will rise while spraying.
How old is the gas? Try draining the tank along with the float bowl and refill it, throw in a new plug and check for any leaks. Then try starting it again.
Did it run right when brought home from work shop?? If not I would take it back and ask em whats up?? Sounds like a air leak problem though but still if you paid to have it worked on and wont run right afterwards Id take it back
  • Similar Content
    • By TheVolta
      New bike is confirmed, your welcome.
    • By DanielX450
      Hey guys I could really use some help. I bought a 2005 CRF 450x that has an aftermarket air filter, full FMF exhaust system (pipe and header), removed backfire screen, and removed air snorkel. Bike idles and starts just fine, but when I hold the throttle anywhere from barely at all to about 1/2 it bogs, wants to die, and backfires. Seems like lean running conditions to me because if i leave the choke on the problem mostly goes away. Additionally, if i move the air screw out almost all the way (to the point where it could vibrate off), it seems to clean up a little bit. I am trying to determine whether bigger jet(s) would fix it or if its something else. My dad thought it might be the float level, but I'm really not sure. Thanks in advance for your help!
    • By pro dirt
      hi, I'm buying a crf450x and this is the first 450x I'm gonna own but i was a bit confused on one of the pictures. i checked on other crf450x pictures and could not find this on any of the others. There is a gap right below the air filter and above the swingarm and I was wondering if it was normal.
      Thanks!!!
    • By David Rediger
      I have a 05 CRF450X that was just rebuilt that is not starting via its electric start. I can start it with the kick starter as well as a rolling start down a hill though. Once started it seems to run just fine. I have it at a bike shop right now and they are stumped as well. So far I know the battery has been tested/replaced, the carb has been cleaned, jetting is good, and they have also tested the starter motor and things all look okay. Any ideas where to look next?
