Suspension Help- CR125.
I searched but couldn't really find what I needed, so here it goes.
Bike- 02' CR125.
Me- 170 lbs. But planning on losing some weight REALLY soon, so count on about 160. Riding MX only.
I'm quite new to riding, so i'm not sure if I can even benefit from setting up my suspension right, but i'm sure it will help some.
What I really need help with is knowing how to set the "clickers"(As I've read?) back to stock, so I can work from there.
I have a manual so i'm not going to really ask the definitions of all the words, as i'll look it up as I go. Sag,clickers, etc.
Like I said, all the help I really need right now is how to set it back up to stock. I don't even know if it's been messed with, I just want to make sure so I can make changes.
I really don't want to mess anything up, so the more details the better.
Thanks alot!!!! :thumbsup:
hey mate, here is what I was told were standard settings...
Shock:
Comp - 18 pos. w/Std being 11-14 clicks
Rebound - 30 pos. w/Std being 18-22 clicks
Spring Preload Length Std = 267mm, Min.=257mm
Fork:
Comp - 20 pos. w/Std being 8 clicks
Rebound -18 pos. w/Std being 12 clicks
I just got my suspension revalved and and setup for my weight, once you get to you final weight definitely get it setup for your weight. It is arguably the single best mod you can do to your bike
take it easy
  • Similar Content
    • By Roman Krzyzanowski
      I have a 2000 Cr125r and I’m in the middle of rebuilding it I just put a new crank and new bearings and all new gaskets so far. I haven’t made it to the top end honestly I’m kinda stuck at this point I &%$#@!ed up and didn’t take pictures while taking it apart mistake on my end because I can’t even find any pictures or anything on it now. I already put the cases back together I’m now on the shift brake pause side I was wondering if anyone could help me with a few pictures of that side of the motor if someone had some? Or send me a link of a diagram of how it’s supposed to be and look. this is the only part I’m stuck on it’s pretty tricky but after that i just got the top end I really appreciate any advice or any pictures y’all come up with or diagram EVERYTHING helps I’m kinda dead in the water at this point ..
    • By 870
      I have a 2005 cr125 new to me. I had millennium tech replate cylinder and supply new piston. I replaced crank bearings and now it won't hit power ban. It feels like a 4 stroke bouncing off rev limiter. It is also putting a lot of black spooge out of exhaust i mean a lot. The plug is black. I cleaned carb and adjusted floats. I also repacked silencer. I noticed the carb leaking gas out overflow the other day. I suspect it is running really rich. I have a brand new pwk from Jd jetting I'm going to try out. I also did a leakdown test and it held. I also am not 100% sure the power valve is set up right. The manual doesn't go into great detail about this. But it seems like there is only one way to put it back together. I have the engine out I'm going to do another leakdown test and double check my power valve and put it back together with this pwk. Any other thoughts out there?
    • By rrrak86
      Hello all!! I picked this up yesterday.  New to me 1997 RM250.  It has Rockstar graphics on it and the guy said it's a Rockstar edition bike.  I can't find anything online that would give me any details.  It looks to have the correct graphics and the radiator shrouds are purple.  Any ideas where to find out the details for these editions?
    • By 101 2-storke
      I have a 2003 Honda CR125R and am looking to get an aftermarket break pedal. but cant find any that will fit my bike. so I'm wondering if one for a 2004 CRF250R would fit my 2003 CR125. anyone know if it will?
    • By aminem
      I have never ridden 2t dirt-bike , i start my dirt bike adventure this year with a 4t yz450 and i love this sport. now am interested to test 2t cross and want to use it for enduro and MX. are this bikes ( yz250) good for both enduro and MX use !? i heard that yz250 is the same from 2006 up to 2016 and have no change . what about honda cr250r !? which year and model of this two brand worth owning !?
