Rev boxes, Good idea/Bad idea?
I have seen rev boxes on American ebay. They seem to replace the cdi/ecu/whatever they are called and it allows the engine to get 3000rpm more (or near enough). Good idea? Has anyone got one fitted?
Most are junk,do not start, or start well, do not rev to the advertised RPM, run poorly.
No stock DRZ can use the extra RPM's, and most modified ones are not making extra power above 8K or so.. The over rev is useable in some conditions, but few. Spinning a DRZ motor above the stock RPM limit requires valve train mods in the least.
+1 junk, save your money
Ideal, I thought as much. Cheers guys
If you have a European S or SM it does make sense, as they changed the mapping in 2nd, 3rd and 4th gear in order to reduce noice.
It would be best (savest) if you would switch to an E or K CDI.
Revboxes sold on eBay are 99% Procom Junk, sometimes under a different label.
I'm one of the few people who had 'luck' with the Procom; I had to send it back to the USA for three times in a row, until I received one with a serial no which I didn't receive before:
PE-C-MS/K400-A-HI
Stay away from the rest as they will NOT work!
Make sure you read the instructions coming with the CDI.
Good luck.
PE-C-MS/K400-A-HI
wanna buy one that has a misfire at 8k rpm?
this is the yosh box number.they are just as prone to issues.
Mine that is labeled yosh is a pos that misses as well. Never got them to honor their screw up. I do have one of the testers they shipped out that I really like, it never did make it to production as far as I know, which is just as well because I know of at least one other drz that wouldn't be started with it and I think there is a second one too. Mine starts with it kind of begrudgingly but once running it has a mid and top end that is much stronger than the stock E that I have. I'll never pay for another product made by procomm that is for sure, no matter whose name is on it.
Once in a blue moon an older Yosh box by Mitsubishi appears on Ebay but these are few and far between... The rest just spell trouble...
Thanks but no Eddie.
I had several version with a misfire, but I estimated it was at 6k.
I don't trust the Procomm; when I go abroad I'll always bring the Mithsibishu in my toolbox:ride:
Good luck.
Would this make much difference? What exactly is an e or a k cdi? Sorry, I'm not really up on electrics
The only difference between the S/SM and E/K (thats model of bike) is the RPM limit.. E (dirt only version) and K (kick start only dirt version no longer sold) has a 500 higher RPM limit. No difference in ignition map.
CDI with a different ignition map made for a region has been stated a few times, Noppy,, do you have a special part number for this Eu region part? I'm not seeing it in any parts book I can view.....And PROCOMM says they are all the same,, they have made different maps,,,, but, not for different markets,, just different runs of production. I'm not sure where this information comes from ????? Word of mouth? or manufacturing data from OEM or aftermarket source? .
71 = K model
72 = E model
73 = EU SM
75 = S/SM model
taken from this thread
There is a difference in part numbers, initially we put it down to EU pollution stuff. Could a remapped CDI also help with pollution stuff?
Cheers, Its not really worth getting it for 500 extra rpm
It is if you want to pick up a second cdi so you have a back up. I have a couple of them.
You will hardly use the extra rpm's. It is the extra torque you will notice all the time.
I suspect that the quality between the batches produced is very (Chinese) different each time.
I guess I was lucky:ride:
As do I... one Procomm holds the garage door open, one helps to level a set of shelves, one makes a nice chock block for the pressure washer:p
No, but noise is environmental to some people:blah:
Go on then, How much with postage to the uk? cheers
Not selling my cdi's right now, only have one that I totally trust (the stock one). The yosh badged procomm is OK with just a slight miss between 8-9k according to the dyno my bike was on, and the other one I have is a non-production unit that has shown to not start every bike, just certain ones:excuseme:
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
